Re: 571
« Reply #375 on: September 10, 2014, 04:32:29 PM »
If I were UPS, I'd ask for packaging pictures from me, and I'd deny the claim.
They should have been in a small box in the big box and they'd have been fine. They probably were just bagged? Shitty.
Re: 571
« Reply #376 on: September 10, 2014, 08:05:17 PM »
Speedway comes through again. Second time I've had a shipping issue with them - first was a site shipping time calculator being a day off and they comped me $20. This time they're 2nd daying the full set of lost parts. I told them that I was hoping to work on my shit this weekend and ETA is Friday. Hopefully they all arrive this time. Or at least that one left hander does...
Re: 571
« Reply #377 on: September 12, 2014, 08:29:53 AM »
Never dealt w them.
Why not summit?
Re: 571
« Reply #378 on: September 12, 2014, 09:09:04 AM »
1" heims are not a common item. They had them.
That said, I've done a TON of business with Speedway and they've always been really good. I'm probably 40/40 between Speedway and Summit. 9% Jegs, 9% Ruffstuff, 2% Fleabay/clist for nearly all the rest.
Re: 571
« Reply #379 on: September 12, 2014, 10:59:27 PM »
Arrived. No box improvement. Large bag inside w all parts in it. Probably good for loose parts recovery in the ups system...
Re: 571
« Reply #380 on: September 15, 2014, 10:35:16 AM »
Matt, is my 6th tire race ready? I need to dismount and look at my spare. Small sidewall pinch, but potentially split the rubber at the bead. Wheel is narfed real good there but the bead looks whole - but it leaks almost as fast as I can fill it.
I somehow missed buying 3/4" bolts last time I restocked, so I need to pick up more hardware. I have 9/16, 5/8, and 7/8. Fail... Need to stock toplocks too, and restock a few sizes already. I used a LOT of 1/4" in the trans swap floor project.
When I picked up my lowboy I was going to grab shock oil and shims out of the Ford. I guess they're the the shop though. I don't know that I'll have/make time to get into the shocks at all. At most, I think I'll try to swap a complete remote res and top off the oil. Anyone know the spec for IFP setting pre-charge? I can probably fake that pretty well when swapping the whole unit but need to know for a full rebuild if getting into the remote.
My rear springs are sitting like SHIT and wearing the hell out of the bottom caps. Seems all the Blue Coils did this. I think it needs some PAC love - but probably wrapped around some Fox 2.5s. That sounds expensive.
prerace punch list:
swap remote resi and bleed shock
Get one, hopefully 2 good spare tires
fix brakes. probably new master cyl unless there's a leak I haven't noticed.
install heim joints on front uppers
Nicities:
front diff seals, check wheel bearings
trans kickdown cable
Heims on rear uppers
Weld up small truss crack on rear at diff
I think that's it. Smike has the right lifestyle for racing....
Re: 571
« Reply #381 on: September 15, 2014, 10:38:22 AM »
shock oil in shop
spare tire looks ok.  has a small bubble in the sidewall- looks like a cord broke or something
shop is a mess from unpacking, but we have two 100% functional cars that dont need any prep really.
Re: 571
« Reply #382 on: September 15, 2014, 10:52:12 AM »
Day Job
DOG (devil with 4 legs)
Woman
Mortgage
There's still room for racing!
Re: 571
« Reply #383 on: September 15, 2014, 10:58:59 AM »
That's great that they just need a checkover and cleanup and no known WORK!
Re: 571
« Reply #384 on: September 15, 2014, 11:19:30 AM »
Oh and you definitely need a UTV.
 Flashy wrap design
A Custom Wide Open Design Cage with Wake Board Boat Speaker Pods are a must.
Walking is for spectators.
LOL
Re: 571
« Reply #385 on: September 15, 2014, 04:01:04 PM »
Fastenal Henrietta was a mess in the 3/4" area.
Found what I needed for coarse thread after resigning myself to fine thread - it was the third mis stocked item in 5 bins.
Jokinen Inc has about $92 purchased, paid for on the spot.
Re: 571
« Reply #386 on: September 15, 2014, 04:04:49 PM »
i have a bag of fine thread 3/4 toplocks that are useless to me  bag of 50  up for trades
Re: 571
« Reply #387 on: September 15, 2014, 09:19:00 PM »
This was on a Slime wheel so it's not a "clean" wound.
Try to clean with soap and water? Brake cleaner? Not sure if that would hurt the rubber...
Spread it as far as I can without ripping more and slob it up with rubber cement? Gorilla glue? Or try to get it vulcanized?
Bead cords feel whole...
Re: 571
« Reply #388 on: September 16, 2014, 12:54:23 AM »
when did you get a flat?  cant see what im looking at.  i have had good success with patch work, but a bead lock clamp helps a lot with close to bead stuff
Re: 571
« Reply #389 on: September 16, 2014, 07:39:03 AM »
That tire was going flat when I broke the link. Inner bead, left rear, pinch.
The bar code sticker is the bead seat. It's right at/ through the rim protector.
