Author Topic: 571  (Read 264517 times)
Re: 571
« Reply #345 on: August 13, 2014, 01:03:11 PM »
matt should have a bunch, i might have some in the shop also.  we gota few last J/J trip
you pick up a co driver?
Re: 571
« Reply #346 on: August 13, 2014, 01:55:43 PM »
Taking 323nate around during prerunning. Can't remember if nets are needed, but it's anotherfuckinthing that needs fixin, and it's quick so it should just get done
Re: 571
« Reply #347 on: August 13, 2014, 03:25:10 PM »
I have seatbelt buckles let me know
Re: 571
« Reply #348 on: August 13, 2014, 03:53:47 PM »
I will be looking for one thursday evening sometime.
"family time" tonight (damn that sounds weird to say)
Ryan, I know you said you'd check what parts you have, would you potentially have any valve stacks? I'm hoping I can find a rough patch and get Nate to shoot some video for me friday to get a baseline for initial shock changes when I open them up. I've done some reading and watched some videos, I'm ready to play some voodoo. I'll be wishing for bypasses pretty much instantly, and surely questioning my Legends-eligible choices. Topics for another thread since we have three cars that need this work.
Re: 571
« Reply #349 on: August 13, 2014, 04:47:13 PM »
Profender shocks will not use conventional valve stacks like the Fox or King, you will need to adjust valving on a shim basis, changing out shims for larger or smaller in the stack. They do not have the full stack tuning ability that you read about.
Im sure I have valve shims around somewhere, I will check.
Re: 571
« Reply #350 on: August 13, 2014, 05:11:20 PM »
I have many many 2.0 valve shims, and 2 2.0 shaft seals.
Only a couple 2.5 shims.
Re: 571
« Reply #351 on: August 13, 2014, 05:52:57 PM »
no IFP seals?
Don't suppose you have a drawing or pic of the valving? I don't understand what you mean.
http://www.pirate4x4.com/forum/general-4x4-discussion/1115042-shock-valve-shims.html
Mkay, so it's a matter of having fewer diameter and thickness choices and a less progressive stack than others? Compared to the pics I've seen of Fox and King stacks there's a LOT less taper and a lot more repeated sizes there
Re: 571
« Reply #352 on: August 13, 2014, 06:29:45 PM »
Yes, Profender will be more trial and error than the Fox. More stacking of the same size shims to get to where you want.
You will need to create a "flutter stack" to get what you need.  http://www.crawlpedia.com/shock_tuning.htm
Re: 571
« Reply #353 on: August 14, 2014, 08:21:54 AM »
Good link, thanks
Re: 571
« Reply #354 on: August 14, 2014, 04:58:43 PM »
Matt has some extra seat belt buckles.
i dont have my phone on me today.
Re: 571
« Reply #355 on: August 14, 2014, 05:52:22 PM »
Still stuck at work. Yay
Re: 571
« Reply #356 on: August 17, 2014, 06:14:23 PM »
Swap welded JJ
Air bump pad
Spare wheel leak
Battery impact
Spares
- Link joints and bolts
- fuel pump?
Re: 571
« Reply #357 on: August 19, 2014, 09:36:54 AM »
Depending how frame side link mounts work out when I go heim, I just wanted to put this here as a sexy sexy idea. I don't think it would work on my chassis...
http://www.pirate4x4.com/forum/general-4x4-discussion/1818681-savvy-currie-campbell-build.html#post27235785
Re: 571
« Reply #358 on: August 20, 2014, 01:03:54 PM »
Very sexy.
Re: 571
« Reply #359 on: August 20, 2014, 11:50:40 PM »
Amazing.  I'd just clear-coat it. No need for paint.
