Author Topic: High Miler  (Read 302659 times)
Re: High Miler
« Reply #855 on: June 10, 2025, 09:00:26 PM »
The U1601 came back immediately after days with batteries disconnected.
Smarty programmer says
CAN ERROR #121 WRONG COMMUNIC.
CAN DIAGNOSTIC 037f1a12fffffffff
And (obviously) won’t connect.
In another place it’ll say ERROR UNKNOWN SOFTWARE
The cluster won’t give any codes. Displays - - - - - - - - and then -done-
SIA didn’t respond to my query. May call them as a next step. Not sure if it’s worth calling a nearby dealership to check likelihood of revival with a reflash. I suspect they’d fail and throw parts at it.
All fuses in TIPM pass continuity
I did not disconnect things and start checking harness continuity. I haven’t looked up a checklist for that. If the right CAN bus wires got chewed I think I’d have no contact as opposed to a corrupt software code but I’m unsure of that.
Re: High Miler
« Reply #856 on: June 10, 2025, 11:01:33 PM »
Have found that the code is specific to anti-tuning security signatures in post-2009 Ecu bootloaders.
Some info here - last answer quotes the tsb that described the secured bootloader
https://www.justanswer.com/dodge/9vhae-07-2500-6-7-cummins-shut-off-driveing-one-day-u1601-code.html
EFILive has their workaround here, but I
1. Know nothing about efilive
2. Don’t have the base tune saved
3. Seems that being in this locked out state might complicate things
https://download.efilive.com/Tutorials/PDF/Cummins%20BootRSA%20Patch%20User%20Guide.pdf
How did I get here though?
I don’t have a fresh tune loaded.  There’s a chance I reloaded the same tune I was already running during earlier troubleshooting, so it had 200-300 miles running since then, minimum. Likely 30,000+.
I would not be surprised if unstable power and fast ecm reboots caused reevaluation of the bootloader or maybe flipped one but somewhere in storage to make the RSA signature incorrect. So this u1601 could still just be a symptom of a wiring issue somewhere.
Fire is looking good, innit Mark?
Re: High Miler
« Reply #857 on: June 10, 2025, 11:14:57 PM »
More every time
Re: High Miler
« Reply #858 on: June 11, 2025, 12:23:06 AM »
Costs enough in parts and licenses to almost entirely chase me away from self solving with efilive.
But if it’s any sort of an ongoing problem, 2-3 times of someone else fixing it and I’m probably there.  Given that cause is unknown….
Their box 625, includes 2 VINs. 125 per 2 addl VINs
Dodge Cummins tuning license 450
(+Another 450 to touch GM stuff)
bench harness almost certainly needed in my present state 400-600 or I’m hunting for Ecu connectors to make my own
I’m also sending out feelers to Cummins parts posts inquiring of computers and harnesses and TIPMs
None of these issues have ever presented in the rain or wet nor after rough roads or any hard maneuvering. Would be a weird harness problem to happen on straight smooth dry roads.
Re: High Miler
« Reply #859 on: June 11, 2025, 06:34:17 PM »
list it for sale high as is, let someone else gamble on it
no idea where truck prices are.
time for the Chevy 50 cummins flat 4x4 do all truck!
Re: High Miler
« Reply #860 on: June 17, 2025, 11:36:53 AM »
at this milage and not running it's like a 5 grand truck, fuck that.
Re: High Miler
« Reply #861 on: June 17, 2025, 03:46:13 PM »
Quote
You will be better off to replace the ecu. that code on the 4945387 pretty much means its at end of life. Get an  updated pn 4945611.
Well OK, then. Done.
End of next week give or take I will know if that was the right call.
Re: High Miler
« Reply #862 on: June 17, 2025, 04:00:04 PM »
what did that set you back?
Re: High Miler
« Reply #863 on: June 17, 2025, 04:48:54 PM »
1400, hopefully minus a 250 core
Re: High Miler
« Reply #864 on: June 17, 2025, 05:01:57 PM »
not terrible.  GVD was 1400 for my 01 like what 12 years ago? ha
Re: High Miler
« Reply #865 on: June 17, 2025, 06:39:54 PM »
Quote
Michael,
I am working on processing your order for the ECM. Unfortunately, there is a massive core shortage for this ECM, and there is no availability anywhere in the country.
 We do have the option to send your core in to be rebuilt. Here is what that would look like for the R&R service on core:
- 10-day turnaround on unit, does not include shipping time
- If your core is NOT rebuildable you would receive full credit minus the freight and a $100 test fee
I sure feel better gambling $250 one way than $100 the other way. I don't like this option...
Re: High Miler
« Reply #866 on: June 17, 2025, 06:56:58 PM »
id much rather find them a core from a yard or ebay and send that then send yours to the wind and hope for the best or at least return of it.  that sucks
Re: High Miler
« Reply #867 on: June 17, 2025, 07:12:14 PM »
Trying another vendor (usdiesel first time, now Dale's), and found another reman that claims in stock and universal to all part numbers with no core charge for 1600 at https://www.fs1inc.com/2007-dodge-ram-truck-cummins-6-7l-engine-computer-pcm-ecm-ecu-programmed-plug-play.html
Re: High Miler
« Reply #868 on: June 17, 2025, 07:13:33 PM »
ebay is relatively thin pickins for cores, fbm has struck out. could try car-part. I have never seen I Cummins in our local yards.
only a 3 year part on my truck too, 07.5-10.
Re: High Miler
« Reply #869 on: June 17, 2025, 08:20:48 PM »
HP tuners says
07.5-09   Dodge Ram/2500/3500/4500/5500 6.7 Cummins (Diesel)
is supported
HPT repository there are only diesel Auto trans base files for 07 and 10.
I looked at both files (free to DL and view) and no option to change to manual trans.
may be worth trying to see if i can pull your file (i forget if you have no OBD comunication working) and then try to force it to another PCM (100$)
