Author Topic: High Miler  (Read 302650 times)
Re: High Miler
« Reply #840 on: May 29, 2025, 01:50:50 PM »
after this round, the important keys grew airtags that I intend never to take off. I HATE the extra bulk of a keychain thing on already thick modern car keys especially, but I'm *done* misplacing critical 1 of 1 items. overdue.
Re: High Miler
« Reply #841 on: May 30, 2025, 08:35:31 AM »
NOT FIXED
FUCK
Re: High Miler
« Reply #842 on: May 30, 2025, 08:39:14 AM »
Wish I’d been logging. Seems like ECU may have no power right now.
Edge CTS not connecting. No crank. Do have dash. 12.2v at cig lighter
Re: High Miler
« Reply #843 on: May 30, 2025, 08:42:14 AM »
No crank after battery disconnect
Gonna leave them unhooked a minute
Re: High Miler
« Reply #844 on: May 30, 2025, 08:51:22 AM »
No crank. Dead in the water
Guess it’ll be easier to diagnose?
Re: High Miler
« Reply #845 on: May 30, 2025, 10:19:25 AM »
Spencer towed me home. Thanks!
Re: High Miler
« Reply #846 on: May 30, 2025, 04:27:53 PM »
symptoms potentially match a TIPM issue. that's about a $1000 parts cannon shot. going to run through all diagnostics that I can find and go from there.
Re: High Miler
« Reply #847 on: May 30, 2025, 08:54:57 PM »
womp womp.
Re: High Miler
« Reply #848 on: June 02, 2025, 09:52:45 PM »
Codes pulled
I did get Ecu connection right away and good vehicle ID
ECU
U1601 - ECU Application Software Code 1 Missing or Corrupted - Active
ABS
C100A - LF wheel speed sensor circuit
C2202 - Original VIN Mismatch/Missing
C2206 - Vehicle Configuration Mismatch
C1079 - Tone Wheel Teeth Count Range Performance
U0100 - Lost Communication with ECM/PCM - Active
Airbag
B212D - ignition Run Only Input Circuit Open - stored
U0156 - Lost Communication with Overhead Module - stored
B210D - battery voltage low - stored
U0019 - CAN B Bus - stored
Central Gateway/TIPM
U0024 - CAN B Bus (-) circuit open - stored
B1669 - Reverse Lamp Control Circuit Open - stored
Electronic Overhead Module
HVAC
Instrument Cluster
P0463 - Fuel Level Sensor 1 Circuit High - stored
P0462 - Fuel Level Sensor 1 Circuit Low - stored
Radio
TPMS (what??)
U0141 - Lost Connection with TIPM - stored
Wireless Control Module
Re: High Miler
« Reply #849 on: June 02, 2025, 10:04:11 PM »
TIPM reports some weird values from PCM/ECU
65,635 rpm
Current speed 318.15mph
All else nominal and accurate to switched position changes and commanded tests.
Ecu functions mostly or entirely give communication errors
Re: High Miler
« Reply #850 on: June 02, 2025, 10:06:42 PM »
Re: High Miler
« Reply #851 on: June 02, 2025, 10:14:20 PM »
Cleared all codes. U1601 remained. ABS codes all remained.
TIPM
U0100 - no communication with ECM/PCM - active
TPMS and SKREEM (wireless) both still have U0141 not TIPM comm - stored
Seems possible to be ECM/PCM (which?) or a wiring harness issue somewhere.
I will check all fuses next step, could be no power to ECM?
Still no crank.
Will disconnect batteries overnight and come back to this
Re: High Miler
« Reply #852 on: June 03, 2025, 09:54:31 AM »
common cause on the internets of u1601 is interrupted tuner coding. might be worth seeing if the Smarty Jr. will talk to it and try to reflash. I haven't touched the tune in ages.
Re: High Miler
« Reply #853 on: June 03, 2025, 05:28:47 PM »
Contacted the ECU rebuilders at SIA electronics who fixed the N14 Cummins ECU for me on Joe.
Fuse and relay checking next, then I need to find a better continuity and resistance check table than I've found to go through the harness between the ECU/PCM/TIPM to check can bus things and supply pins. that'll be a thrill. Might try to get it in the shop, I don't think I've tried to move this one from its tail with the forklift before with the lunette ring.
Re: High Miler
« Reply #854 on: June 03, 2025, 05:30:40 PM »
TIPM is a one year part, '07 2500/3500
ECU is kinda crazy (and I'm making a maybe dumb assumption that pickup and C&C use the same)
Buyer's Guide : DORMAN 318062 Engine Control Module (ECM Computer)
DODGE GRAND CARAVAN 2011
DODGE RAM 2500 PICKUP 2007-2009
DODGE RAM 3500 PICKUP 2007-2009
