Author Topic: 1973 CJ6  (Read 171414 times)
« Reply #720 on: March 21, 2016, 11:25:39 AM »
i have only bought 2' chunks for 4wd.com
« Reply #721 on: April 02, 2016, 06:04:40 PM »
thoughts...?
has some time, sandpaper and paint...
was going to do floor liner, or is the contrast appealing?
I happen to galvanize the shifter boot ring, and had solid core aluminum rivets from the Rover laying around..
« Reply #722 on: April 02, 2016, 06:31:39 PM »
I don't mind the blue accent.  Breaks things up a bit.
« Reply #723 on: April 02, 2016, 06:31:58 PM »
i think bedliner in that color would look cool.  or throw some filler and sanding on someones weld seems that were suppose to disappear in beadliner  :)
« Reply #724 on: April 02, 2016, 07:00:06 PM »
I spent 29 min spraying it...  Wasn't committed or would have done some body work.
Might run it for a bit.  And become lazy and leave it.
« Reply #725 on: April 03, 2016, 10:55:20 AM »
Blue!
« Reply #726 on: April 03, 2016, 04:00:25 PM »
love the body color. run it
« Reply #727 on: April 03, 2016, 09:05:04 PM »
Blasted it tonigh   ;D
Going to try my hand at some bodywork.
« Reply #728 on: April 04, 2016, 09:08:58 PM »
started plugging the bolt holes.
Guy at work said use a penny and weld em up..
The copper conducts, but it doesn't stick. (In a lab)
On a shoddy welding bench it burns, or newer pennies are made of magnesium...
Needs more more grinding before filler..
« Reply #729 on: April 04, 2016, 09:25:48 PM »
I've used small aluminum blocks before with good results.
1973 CJ6
« Reply #730 on: April 04, 2016, 09:55:07 PM »
Ditto on aluminum. good results.
I tried it after seeing brass/copper(?) used.
« Reply #731 on: April 04, 2016, 10:32:07 PM »
Not much Cu in pennies anymore.
97.5% Zn, 2.5% Cu since 1982.
« Reply #732 on: April 06, 2016, 09:31:38 AM »
taillight cutouts from tub worked much better last night
« Reply #733 on: April 11, 2016, 10:23:38 AM »
not pretending to be a body guy.. this was my college try.
filled some holes, smoothed some seams, made it one color..
« Reply #734 on: April 11, 2016, 04:40:00 PM »
I'll drive that! ;)
