Author Topic: 1973 CJ6  (Read 171398 times)
« Reply #675 on: August 11, 2015, 09:12:18 AM »
There should be a little play at the clutch fork with the pedal all the way out, otherwise you've got load on the throwout all the time - if I'm understanding your question right.
yes.. thanks...
have my plunger rod with me today.. a trip to Fastenal at lunch.. who sells a M10 1.25 rod in a universal kit? :o  I think my current setup is short enough that I'm getting a good throw, but only at full stroke..
Things that I have noticed while driving:
If I coast into a parking spot with clutch depressed I sometimes cant pull it out of gear until I give another full pump to the pedal.. an issue when my front bumper is up another cars ass already.
Same situation at a stop light if not in neutral.. seems like I'm loosing pedal.. possible internal hydraulic leak
I have a good amount of pedal movement before anything happens..
had this with my Brake MC and the rod was too short...
« Reply #676 on: August 12, 2015, 02:40:30 PM »
Evap system is coming together...
Cleaned out some room on the driver side firewall for the bracket..
(thankfully I had the premonition to get it hot dipped at an earlier time)
Evap canister is an older Delco unit.. with Fresh Air/Tank/Purge nipples
I am debating where to tie the purge into.. I think I can get away with T'ing it to the EGR valve since its operated by the CTO switch..  Eventually I could always swap CTO's for a dual circuit, not the single I have currently..
Gas tank vent and rollover proved a little difficult..  real estate back there is slim and I didn't want to drill any additional holes into the body.  I ended up using a left over hood prop rod bracket mounted to the rear roll cage foot plate.. the MTS unit came with a stainless bracket that fit perfectly..  Still have to plump the valve to the engine compartment, but the heavy lifting is done..
« Reply #677 on: August 12, 2015, 02:44:22 PM »
also not so important, but I got the front bumper and winch mounted..
ended up using my winch off the YJ, just put some new rope on it.. and ill be putting the new Rock 12.8 I purchased on the Wrangler.
yes, I know its not the correct color emblem... but I thought it matched better  :P
jacel861
  • Full Member
« Reply #678 on: August 12, 2015, 03:21:38 PM »
Bumper looks sharp!
« Reply #679 on: August 12, 2015, 04:51:10 PM »
nice when even the little things start coming together!
« Reply #680 on: August 13, 2015, 08:56:12 AM »
Nice. Nice.
« Reply #681 on: August 13, 2015, 09:04:07 AM »
did the clutch last night...  it functions, that's all I can say..
this is the new pushrod I made...  same length as the one I removed with a coupler/jam nut so I can +/- the length while in the truck.  Once I get it dialed in Ill prob take it back out and make a solid one..
« Reply #682 on: August 17, 2015, 08:36:28 AM »
all buttoned up..
didn't feel like 90 deg was a good day to road test... :o
« Reply #683 on: August 31, 2015, 09:31:14 AM »
aside from shredding though some road cabbage this AM (http://www.whec.com/news/stories/S3893150.shtml?cat=565)
this guy is running like a champ..
little rich, might need some fine tuning in the CPU department..
« Reply #684 on: September 10, 2015, 10:02:21 PM »
Some field testing on the Jokinen estate today.....
First scratch, tree rub, and trail break...
Pics and details tomorrow. ( it wasn't that bad, but all factually true)
« Reply #685 on: September 12, 2015, 03:24:12 PM »
a BIG thank you to Cora for taking some this this past week and allowing me to play around...
Was able to take the 6 out for an hour or so and put through its paces...
Some general driving impressions first...
The Jeep drives great, and I'm not just saying that.
tracks very well down the road, steers well, accelerates and brakes almost like a modern vehicle.
Driving a T18 deff takes some getting use to on the road.  2 and 4th are easy, upshift to third is a slow go and easy to miss.
Engine is beautiful... a pleasure to step on the gas!
Jeeps runs about 2,500 RPM in 4th gear at 60 mph.
I can easily get it to 85, but I'm out of gear . . . almost like a built in safety feature.
long why cruises are easy, but thirsty.
Country roads with a 55 MPH limit are best..  I can get it in 4th and keep the RPMS down.
Off Road Performance
It was odd, I had to lock hubs before popping into 4low, but there were no sway bars to disconnect :)
Jeep hit the woods very naturally..
Trail riding was nice, the narrow stance will keep pin striping down and an ATV trail is very doable.
A big difference is the LWB.  Lots of wide turns and reverse gear was needed to stay on trail.
Rear tire carrier/cage is perfect for pivoting during some of these maneuvers in tightly wooded trails.
Lack of sliders was discovered quickly, some scratches in the aluminum will be a reminder if not sanded out.. ;)
Selectable front locker is a must for any LWB Jeep, was toggling the switch on/off frequnetly.
Suspension needs lots of breaking in or they just don't flex like they do now..
With only 500 miles on the rig and NO weight in the rear of the truck I think they need some time to give a bit.
Gearing is fantastic, wouldn't change a thing 94:1 in LOW was enough to creep down a couple rather steep grades.
the couple rocks on the trail were a quick reminder that airing down is a must.
Cant really judge performance since I was bouncing on and off. (Round 2 hopefully with sliders)
Overall a very successful outing some design changes I noted:
-Power steering cooler might be needed.. lots of turning when trails are tight..
  thought i might have overheated, but could also have been a bad brake flare leaking fluid..
-more slack in front hard brake lines.. nothing broke loose, but I can see a possible problem (or it was a bad flare)
-more HYD spares (flare tool, etc.. all custom, no off the shelf parts if needed)
-SLIDERS - SKIDS
-gear tie downs in the back.. or tool box rack
-phone / GPS holder somewhere in Jeep is needed
-Shift tower boot and Tcase boot.. lost my radio remote through the floor in a quick stop
-T case shifters need to be re angled..
-TBI running slightly rich... 12 psi fuel pressure.. might need to tune down a bit..
-more wheeling will lead to a OTK of the TRE...
Some "full flex" shots followed by some more pictures form the day
jacel861
  • Full Member
« Reply #686 on: September 12, 2015, 05:42:13 PM »
The elusive offroading unicorn shows his head ;-)
« Reply #687 on: September 13, 2015, 09:21:38 AM »
 ;D Whiteness protection.
I've seen a lot of shit.
« Last Edit: September 13, 2015, 11:09:21 AM by rejeep »
CJ
« Reply #688 on: September 13, 2015, 10:30:38 AM »
Proof!
They do exist!
« Reply #689 on: September 18, 2015, 08:17:45 AM »
Drilling holes for passenger side slider this weekend...  :o
