Author Topic: 1973 CJ6  (Read 171449 times)
« Reply #645 on: July 03, 2015, 09:32:20 AM »
whats up with the front?
ok, here is the long and short of it.....
I'm a bonehead... pure and simple...
I went back and checked, double-checked, even triple checked in most cases all the vitals of the car before its maiden voyage..
on paper everything looked good, mental lists checked out and I even torqued the lug nuts...
My first few miles of driving were pleasurable... no issue or odd noises.. truck ran great..
by the time I got to Perrinton I was hearing some rattling from the T-case.. Unsure of what it was I pushed on.. I was actually thinking it had something to do with a loose shifter or ???
Had a very successful customer event in Farmington and spent the afternoon with Cora.. an absolute pleasure...  Ride home was very similar to ride out… all quiet and fine until Constellation HQ on 96..  I said F-it and jumped on 490 to Brighton…  Had some noise, but the tire and open air muffled some of the screams.. the real fun didn’t happen till I got off at Linden Ave.
As I turned on East Ave and was on the home stretch I was soon engulfed by a cloud of burning oil..  several expletives and g-d damn its came flying out and next thing I knew my steering column was 6 inches closer to me that before (it’s not a telescoping column)  I had no steering and was heading toward the curb.  Jumped out and popped the hood … My $15 Rock Auto power steering pressure line failed, didn’t break, FAILED..  The metal separated from the rubber due to a bad crimp.. oil smoke was PS fluid on a nicely coated exhaust manifold.  Called Scotty’s and had one of the guys run out with my MJ and a strap to drag me the mile home.  As I pulled into the driveway I swore off my Jeep for a week.
1 week later and a few calls to SVE I started addressing the issues:
-   T Cases need oil to stay cool and quite.. this would be mandatory, not a suggestion
-   Speedo gears need oil to stop from melting
-   Steering shaft U Joints should be checked several times after install/alignment/miles
-   Lack of power put added stress on above joint
-   Good things aren’t always cheap and cheap things aren’t always good
-   Even if your to do list is crossed out.. double check fluid levels before doing something stupid
Front of the vehicle was up on jack stands to aid in bleeding the PS system.  I also had the rear up so I could manually manipulate the drivetrain without any lockup.  I drained all fluids in the drivetrain to check for metals and whatnot, that is when I discovered the lack of oil in the Dana 300.. I still don’t know what I was thinking.. I was very well away they didn’t share the same oil reservoir and I really recall filling it with the recommended 3qts….
D300 appears to have survived the ordeal…  there really aren’t many bearings in these cases and the intermediate shaft and all 48 needles were slathered with Molybdenum disulfide, … I think this helped keep things alive.
I resealed and FILLED this time around all drivetrain components… Ran in gear without the rear driveshaft and I have 100% quiet operation.  The attached video give an idea of the sounds I was hearing while driving… just imagine amplification and increase speed!!!!
Finally was able to road test last night... up and down the block reveled a working speedo, no drivetrain noise, smooth shifting in all ranges (once the oil started splashing around)
I'm going to give it a week of grocery runs to bring drivetrain up to temp and flush Tcase.
Also noticed the oil pan drain plug is seeping..  going to get a nice molder rubber one instead..
Video:
« Reply #646 on: July 03, 2015, 09:32:56 AM »
on the bright side....
its looking good
« Reply #647 on: July 03, 2015, 09:44:03 AM »
Lucky on the 300 for sure
« Reply #648 on: July 03, 2015, 10:38:22 AM »
CJ
« Reply #649 on: July 03, 2015, 10:49:06 AM »
Wow!!
I remember your comments about the t-case noise and wonkey spedo. Glad it survived! A testament to the stout Scout Dana 300.
« Reply #650 on: July 07, 2015, 09:02:37 AM »
getting some color variation in the rattle cans..
going to we sand and go for round 2 in a better environment..
« Reply #651 on: July 08, 2015, 02:46:04 PM »
Some lunchtime miles on the Jeep today...
no news is good news..
« Reply #652 on: July 14, 2015, 09:48:36 AM »
Badges.. we don't need no stinking badges...
paying homage to the Jeeps roots...
Vinyl decal for 'Jeep' lettering to be replaced by billet one I'm working on..
« Reply #653 on: July 14, 2015, 11:23:33 AM »
very cool.
badges look good
« Reply #654 on: July 14, 2015, 12:07:55 PM »
Looks good Arie!
« Reply #655 on: July 19, 2015, 07:27:45 AM »
Glad were all having problems this weekend...
after 20 miles of uneventful driving I ran into a no start.. seemed the ignition switch was dead...
got the guy fired and Im throwing a CEL and stalling...
ALDL conector not getting juice... blow fuse somewhere...
« Reply #656 on: July 20, 2015, 09:42:39 AM »
Blown fuse or melted harness...
96 deg heat and running around town... harness "fell" off the manifold and touched the back of the engine block..
no wires seemed to be damaged, but I'm sure the heat transfer and molten goodness caused a temporary short and caused the Howell to throw a code..  at least that's what I'm going with right now..
Battery reset and my ALDL now connects, engine runs with no traveling idle or stalling...
more "test" miles tonight
jacel861
  • Full Member
« Reply #657 on: July 20, 2015, 11:09:03 AM »
Since you're going to have so much practice at this vehicle wiring thing,  want to come fix my disastrous wiring nightmare on the Rubicon?
« Reply #658 on: July 20, 2015, 11:17:30 AM »
I hate wires but I love fuel injection...
Zip Ties FTW till I can figure everything out  ::)
« Reply #659 on: July 21, 2015, 08:46:52 AM »
home depot trip last night resulted in having an intermittent CEL...  But it was on when I parked it..
Code 22... THROTTLE POSITION SENSOR (TPS) CIRCUIT (LOW)
Trouble Code 22 indicates that the Throttle Position Sensor (TPS) is reading abnormally low. TPS volts should be close to 0.42V at closed throttle and rise smoothly in about 0.02 volt increments to a maximum reading of about 4.85 volts at WOT.
Code 22 will set if:
- Engine Running
- TPS reading < 0.25 volts for 3 seconds
Typical causes for this code include:
1) Circuit Open or Shorted to Ground
2) Faulty Connection
3) Faulty TPS
4) Defective ECM
TPS cannot be adjusted, the TPS has an auto zeroing feature.
I also noticed I have no parking lights at the moment.. but headlight, brake, backup, turn signals are just dandy..
My horn is also being weird... going off randomly.. I hear the relay click so I know its grounding in the column somewhere..
I figured I was working on the Land Rover when I was doing most of this chassis wiring..  Either a British part was used or the prince of darkness is seeking revenge...  Checking all grounds tonight as well as a new TPS
Clutch might also need a heavier return spring and a gooder bleed..
