Author Topic: 1973 CJ6  (Read 150078 times)
« Reply #225 on: January 11, 2014, 09:48:05 PM »
pretty!
« Reply #226 on: January 12, 2014, 09:01:24 AM »
Looks awesome
« Reply #227 on: January 12, 2014, 04:35:34 PM »
have to design a tub lifting rig...
Im thinking some 2x4 and a single eyelet...
going to have to find the COG for a CJ6...
« Reply #228 on: January 12, 2014, 08:16:26 PM »
Got some misc work done on the frame today..
Started the running the rear brake lines...
76-86 SS flex lines do not work with the 73 pre bent SS lines..
Need some adapters... :o
Motor frame mounts positioned.. and of course 72-75 Jeeps require some "drilling modification"
New lower shock studs made.. better alignment with the top studs.
« Reply #229 on: January 14, 2014, 08:17:14 PM »
What brand motor mounts?
I know u have brown dog in the yj.
Looking to purchase new HD for cora's 360 in lieu of fab.
« Reply #230 on: January 14, 2014, 09:26:17 PM »
M.O.R.E
« Reply #231 on: January 15, 2014, 07:29:27 AM »
Thank you sir!
Motor looks very good.
Makes cora's look extra dirty!
Planning some prep time on that this weekend.
« Reply #232 on: January 15, 2014, 08:04:35 AM »
i have some extra and spare almost everything if you need...
engine related that is..
« Reply #233 on: January 15, 2014, 08:40:28 AM »
K thanks
I'll see what I get into.
Right now only thing I'm thinking I need to do is
New PSC Steering pump and Sealed housing
Remove clutch fan
New belts & Hoses
New plugs
New Mean Green Alternator
New Starter
Do you have any 2 bolt factory style exhaust flanges?
Manifold to down pipe side?
We are planning to still run stock manifolds but the previous exhaust system had undersized flanges and they warped and always leaked.
« Reply #234 on: January 17, 2014, 10:41:15 PM »
crossmember mounted tonight... seems there are 2 stock positions so its just finger tight for the moment..
yay fastenall for all new flange bolts and nuts.
« Reply #235 on: January 17, 2014, 10:43:59 PM »
picked misc CJ6 parts and MJ bumpers from powdercoat...
« Reply #236 on: January 19, 2014, 07:58:52 PM »
tackled steering this weekend..
Box mounted on new bracket..
Steering box brace mounted...
Missing Pitman arm nut... so all progress kinda halted here..
getting ready to plop the engine in the frame...
« Reply #237 on: January 19, 2014, 09:21:29 PM »
Odd question....
Anybody mount a fiberglass tub or repli tub without scribe marks?
I was just thinking what would I have to reference that the tub is in the correct position...?
I haven't actually mocked the tub on the frame yet.. So if there is an 'ah ah' factor here I apologize..
« Reply #238 on: January 19, 2014, 11:36:06 PM »
Put the steering shaft and column in and connect to box.  Nothing else matters.  No marks any where.  Both i have done were the wrong match tub/frame
« Reply #239 on: January 20, 2014, 12:31:23 PM »
Not a bad idea..
I was also thinking use the center mount for the grill and work back with the fenders installed then tub..
Might get the tub over to the garage this week..
Motor is almost ready to drop and some garage updates being done today that will make life rather easy 8)
