Author Topic: 1973 CJ6  (Read 170946 times)
« Reply #240 on: January 23, 2014, 10:18:57 PM »
Chassis body....
body meet chassis..... 8)
they finally meet face to face....
« Reply #241 on: January 25, 2014, 07:22:14 PM »
Such a pretty tub!
« Reply #242 on: February 01, 2014, 03:16:26 PM »
Engine wrestled in the frame today...
« Reply #243 on: February 02, 2014, 04:18:56 PM »
degreased, sanded, and a coat of primer on the gas tank...
purchased some Eastwood gas tank paint I decided to try...
I think its nothing but a zinc rich paint.. almost like a cold galvanizing spray...
Started putting together the swing pedal assembly..
pressed in the new bronze bushings and cleaned up the hardware..
« Reply #244 on: February 02, 2014, 11:01:06 PM »
This rig is turning out to be nicer than when it came out of the factory :)  Keep the updates coming!
« Reply #245 on: February 03, 2014, 09:09:48 AM »
After showing my wife the picts from this thread she stopped complaining about me dragging a hood through the living room.
How much of the build will be with the original parts? those original parts are older than me ...
« Reply #246 on: February 03, 2014, 10:15:01 AM »
with exception of the tub, everything is original to the era....
tub designed in era spec however...
but to be even more specific... nothing has been removed (yet) from the original 1973 Jeep I purchased...
I like to buy NOS when possible.. makes fitment and function issues nonexistent…
I happen upon a large hoard of 72-75 parts... that’s helped tremendously.
Nothing dragged thought the house yet…
Don’t tell my wife, but I conceded to buy the house because of the garage space…
Mike, Paul, and Jared have seen it firsthand…
« Reply #247 on: February 03, 2014, 10:22:02 AM »
So this is a scratch build to match the '73 using generation parts? Wow.
Dragging a hood or an axle through the living room is a great way to do the following:
1. Convince wife you need heat in barn.
2. Get sent to the the banishment room for a while.
Not in the order of course.
« Reply #248 on: February 03, 2014, 10:51:48 AM »
I guess that’s a good way to put it.. I’m building from scratch...
It’s the no skimp Jeep I always wanted build...  don’t know how long it will take or how much, but I promise it will be sweet...
I happen to have more garage time now and a good enough collection of parts that it seems like I’m cruising..
but I guarantee a screeching halt sometime in the coming months....
« Reply #249 on: February 05, 2014, 09:09:24 AM »
ran into my first real hurdle with this guy..
body doesn’t want to sit square on the frame..
stock body mounts should be 5/8’s.. I think I’m getting high centered on the load floor support to the cross member..
also the 5/8 body mounts made it impossible to run the finned fabricated valve covers..  I am going to have to use stock style ones at this moment.
There were a few 15/16’s spacers in the kit and I used them at the cowl..  seemed to give me enough lift to get the rear support off the cross member.
Going to call prothane today and see if they sell individual mounts.. if not I don’t know what I’m exactly going to do..
Here is the cross member....
Some of the valve cover clearance issues...
I had some cheap 29.99 chrome guys that’s I used to paint that I might be able to get away with...
Believe it or not the body IS centered....
seems the rear cross member is not exactly even....  unsure why at this point...  something the rear bumper and a sawzall will fix...
Teaser shot.... everything lined up nice...
« Reply #250 on: February 05, 2014, 09:17:04 AM »
The last pics I see are from your 2/1 post.  Just me?
« Reply #251 on: February 05, 2014, 09:22:22 AM »
I see em all.
if you click, the links to PB work as they should for me too
« Reply #252 on: February 05, 2014, 09:23:39 AM »
I see them.
Maybe a 1" body lift.?
« Reply #253 on: February 05, 2014, 09:28:04 AM »
pre 75 jeeps are hard to find mounts for.. just the stock 5/8" spacers...
I have 2 prothane sizes in my hand that are 15/16' and 1 5/16"
I’m going to see if they can sell those individually..
« Reply #254 on: February 05, 2014, 09:51:12 AM »
Either that or buy another full kit?
 Or is that still not enough of the correct size?
Can you shift backwards to gain more valve cover clearance?
Hard to tell from the photo.
Rear of tub flush with bumper mount?
