Author Topic: 1973 CJ6  (Read 171282 times)
« Reply #60 on: February 27, 2013, 10:00:44 PM »
The body has been hacked into before..
Notice one side had the early jeep logo while the other has the intermediate and the V8 badge...
But yes and no.. I have seen them either way, but never without a seam unless filled in.  The driver side is the same, just not as pronounced due to the angle of the picture...
« Reply #61 on: February 28, 2013, 09:11:34 AM »
didn't notice that till you pointed it out.  it's got some rot but a LOT of potential
« Reply #62 on: February 28, 2013, 10:21:59 AM »
going to fill the MC today and play with the brakes a bit....
might just need some love...
« Reply #63 on: March 01, 2013, 02:40:14 PM »
got the rear to lock up... giving me enough brake to drive around a bit...
« Reply #64 on: March 05, 2013, 10:16:54 AM »
Frame arrived in Rochester last night...
is in better condition than expected to be honest...
« Reply #65 on: March 05, 2013, 10:59:23 AM »
Blast and powdercoat?
« Reply #66 on: March 05, 2013, 11:30:33 AM »
depending on what gets screwed, glued, or welded I am thinking Hot Dip Galvy after its all mocked up...
« Reply #67 on: March 07, 2013, 08:35:25 PM »
spent a little time looking the frame over...
Smike I might be making a punch out list for things I need welded...
this is the passenger side shackle hanger..
the sleeve is all rotted out..
the passenger rear is close to the same while the drivers side is "ok" but would rather be safe than sorry...
will these work?
http://www.ruffstuffspecialties.com/catalog/merchant.mvc?Screen=PROD&Product_Code=BUSHDOM
« Reply #68 on: March 08, 2013, 07:41:49 AM »
If thats the case. Cut them off and buy new 1/4" thick hangers too.
« Reply #69 on: March 08, 2013, 08:04:35 AM »
Coil buckets?
« Reply #70 on: March 08, 2013, 08:07:25 AM »
leaves are found naturally in the woods... coils on the other hand
« Reply #71 on: March 08, 2013, 08:11:13 AM »
is that bracket the inside leave mounts?  i dont under stand the picture, or is that the outside mounts?
« Reply #72 on: March 08, 2013, 08:24:23 AM »
that’s the front shackle hanger.. there is suppose to be a metal sleeve there that rotted out where the bushings go into for the top shackle bolt...
I am debating between replacing the whole mount with a Ruff Stuff piece or leaving the factory riveted hanger and just doing the sleeve…
Thoughts?
« Reply #73 on: March 08, 2013, 08:32:46 AM »
being a 73, i bet the sleeve wasnt installed, those things are beefy- no way it rotted.
i guess it would depend on what springs your putting under it which way to go with the mounts-
« Reply #74 on: March 08, 2013, 08:38:47 AM »
Aren't YJ leaves wider anyway?
