Author Topic: 1973 CJ6  (Read 170786 times)
« Reply #90 on: March 22, 2013, 02:19:15 PM »
as is said around here....
More shrong parts for the enviable build.....
« Reply #91 on: March 22, 2013, 02:52:30 PM »
been toying around with some frame reinforcement ideas...
in talking with Bill@SVE and a few measurements at lunch came up with this......
just to box right above the spring hanger and extend a little bit outwards..
kind of a tweak on the original HD renegade frame design.. the squared off box created stress points that would cause cracks..
the fish plate design of the above plate should disperse the load over a broader area..
Still need to work on something possibly for the front and rear shackle hangers, but those traditionally aren’t a problem area.
Smike.. if I can draw it you can make it out of metal right?  were only talking 1/8" plate
« Reply #92 on: March 22, 2013, 03:37:28 PM »
already revised....
radius cut would be better....
no issue for Hole Saw and band Saw tag team!!!
set it into the C a bit for good penetration with the weld....
I think we have a winner...
« Reply #93 on: March 22, 2013, 04:48:32 PM »
i have a plasma cutter
« Reply #94 on: March 22, 2013, 04:49:52 PM »
id go 7gage or 3/16" to match the frame thickness.
« Reply #95 on: March 24, 2013, 09:49:08 AM »
I think the frame is 1/8"
I might be wrong...  can measure
I want to keep around the same thickness for the Galv process..
as long as I can get all my ducks in a row is this something you can start on possibly next week...
Mike... can I use your enclosed to move it and store it @ M4...
Ill bring it back to Carter for perm storage when smike is done...
1973 CJ6
« Reply #96 on: March 24, 2013, 12:14:49 PM »
Sure.
Good timing, I was thinking of grabbing it today to throw an Eagle in.
« Reply #97 on: March 24, 2013, 12:44:49 PM »
any time table on your end?
i was thinking this week.. just unsure exactly when
« Reply #98 on: March 24, 2013, 01:33:13 PM »
Let me get the mj done, and I can drop it and grab the frame in my trailer.   I'm pushing my outside storage with 9 trucks and 2 trailers.
« Reply #99 on: March 24, 2013, 01:43:54 PM »
got it... I'm in no rush....
« Reply #100 on: March 25, 2013, 12:41:40 AM »
Mj done.  Can drop and grab frame any day this week except wed.
« Reply #101 on: March 25, 2013, 07:31:20 AM »
hmm.... ok let see how this week turns out
« Reply #102 on: March 25, 2013, 03:06:23 PM »
so my trailer isn't needed?
it's probably on moving duty soon, my old boss is headed to Cleveland at the end of next week.
« Reply #103 on: March 25, 2013, 03:07:57 PM »
i think we have a plan and in the works.  should be good with out trailer
« Reply #104 on: March 25, 2013, 03:52:23 PM »
life is easier when you dont have to tow....
i have the hitch lock key...
i have to be up there tomorrow around 2 i can prob swap it out for a padlock so you can grab when you need it..
