Author Topic: 1973 CJ6  (Read 170625 times)
« Reply #855 on: July 25, 2017, 10:49:13 AM »
Had one in the Rubicon, perfect for wallet and sidearm.
« Reply #856 on: July 25, 2017, 11:03:49 AM »
I was thinking wrenches and an ignition box... ;)
« Reply #857 on: July 31, 2017, 08:54:10 AM »
little update on the ignition box gremlin issue...
make a very long story short..
The ignition module ground (black wire in harness) grounds through the distributor.
The distributor is in fact grounded via the distributor hold down clamp...
I created a secondary ground from the vacuum advance screw to the engine block.
4 tanks of fuel later and no issue...
note to self:  don't powder coat distributor hold down clamps...  ::)
« Reply #858 on: July 31, 2017, 09:25:51 AM »
Ready for AOAA wheeling?!
« Reply #859 on: July 31, 2017, 09:41:55 AM »
thats odd, so since it probably has a cork gasket under it, it was trying to find ground though the drive gears / oil pump?  hmmm
« Reply #860 on: July 31, 2017, 10:18:41 AM »
exactly...
I hope
« Reply #861 on: July 31, 2017, 10:35:33 AM »
that's a great find! what a pain!
« Reply #862 on: July 31, 2017, 01:25:10 PM »
Its always something so stupid!
« Reply #863 on: August 30, 2017, 01:32:40 PM »
just ranting.. but I'm done with shitty aftermarket parts..
little more homework this weekend..  looks like a MSD ignition box is in my future..
« Reply #864 on: September 19, 2017, 08:38:48 AM »
Chrysler ignition box installed last night...
Chrysler ignition, Ford distributor, AMC motor, GM fuel injection system.. ::)
Jeep runs like a raped ape now..
snappier throttle response and easily bolted on 20 HP  ::)
removed the hood to cowl seal and im getting a bit more air draw out of the engine compartment..
time will tell..
« Reply #865 on: May 25, 2018, 04:20:21 PM »
This thing looks insane on the highway! Nice!
« Reply #866 on: May 26, 2018, 07:57:42 AM »
Believe it or not it’s a great hwy ride..
It’s been a pleasure to drive...
Where was I?  Been all over the place lately.
« Reply #867 on: May 26, 2018, 08:57:02 AM »
Coil has been good?
« Reply #868 on: May 26, 2018, 09:49:31 AM »
It’s been smooth, functional and reliable.
Not to jinx anything, I’m still tweaking..
Been playing with tire pressure and I have a vibration at 30/35mph..
I’m assuming it’s due to solid mounted everything, but I’m still touching everything again..
Engine runs warm.. not a bad warm, but a custom fan shroud would be nice eventually..
Still not addressed:
AC Charge
Re galvanize hood hinges
Washer pump
« Reply #869 on: May 26, 2018, 10:18:11 AM »
Driveshaft angles? Or improper yoke clocking? Just my first suspicions.
