Author Topic: 1973 CJ6  (Read 170636 times)
« Reply #870 on: May 26, 2018, 11:16:51 AM »
going to check both
« Reply #871 on: May 26, 2018, 02:21:46 PM »
Where was I?  Been all over the place lately.
590s at 490. Hoggin in the left lane!
« Reply #872 on: June 15, 2018, 05:53:08 PM »
Spectacular weather and driving lately...
harshly interrupted yesterday..
Had a couple shut downs while driving the past day or so...
Fuel pump cut out..  didn’t hear it prime with an ignition cycle.
Was able to restart within a few seconds/min of waiting.
Howell suggested relay...
Fun...
« Reply #873 on: June 30, 2018, 08:50:32 AM »
Regular maintenance lead to this discovery..
I knew this was on borrowed time... sad thing is it happened on pavement.   Sections of East Ave. are like downtown Baghdad.
« Reply #874 on: July 16, 2018, 08:23:36 AM »
Good enough
« Reply #875 on: July 16, 2018, 09:09:23 AM »
Better than OE!
« Reply #876 on: July 16, 2018, 10:12:55 AM »
grind the rivets off, have these galved, bolt on with galve hardware
https://www.morris4x4center.com/crown-upper-shock-mount-bracket-805635.html
« Reply #877 on: July 16, 2018, 02:04:58 PM »
Already on that plan...
Arrived UPS this morning...
Easier to trim and reinforce the mount on the bench.
Winter project...   want the truck to drive while it’s nice
« Reply #878 on: July 16, 2018, 02:07:42 PM »
I would have to weld nutserts in the frame...
blind hole with the boxed front section..
« Reply #879 on: July 16, 2018, 03:23:50 PM »
swap it for my 49 for a day or two and bring it back with a sticker i would have done it for you :)
« Reply #880 on: July 16, 2018, 10:33:48 PM »
That could be doable
« Reply #881 on: July 16, 2018, 11:30:12 PM »
any time let me know.  its too fun to drive.  electric wiper conversion kit in the mail.  not even sure it needs wipers to pass, otherwise all good.
« Reply #882 on: July 17, 2018, 05:57:52 AM »
I can get a sticker on a rickshaw if needed
« Reply #883 on: July 21, 2018, 02:46:27 PM »
Fun...
New computer installed.. so far so good
« Reply #884 on: August 11, 2018, 05:40:28 AM »
4000k mile service
All new fluids, grease, coolant, heater core block off and a 180 deg Tstat.
The new Tstat brought engine down to “normal” operating range.
I got tired of looking a gauge creep up to 210-215 at times, although totally normal for AMC’s.
Running on the hwy yesterday at 80mph barely made the gauge hit 195 (the previous Tstat)
To culminate the achievement, the fuel pump relay finally crapped out in my driveway.
It was perfect... got home with the family and truck died in driveway.
Little diagnostic time and a jumper wire lead to faulty relay diagnostic...
I had the old Hella relay in the garage and swapped that out meantime.
Where were these relays mounted in stock applications? (GM truck) When I asked Howell about possible engine heat killing these they told me “it gets hot in the desert.”  The unit that failed was an aftermarket part.  Ordered a few Hella and Delco units last night, just wondering if I should move it all off the firewall.  What else could make these fail?  I think there are only 2 grounds in the loop, fuel pump and main harness.. will clean both as well...
There is something to say for the simplicity of a Carburator..
