Author Topic: matts buggy build  (Read 193900 times)
Re: matts buggy build
« Reply #795 on: April 04, 2018, 08:21:41 AM »
Now we know the thickness of a 60 spindle.
« Reply #796 on: April 04, 2018, 08:29:17 AM »
That’s kinda impressive but sucks that it had to break at KOH.
Did you broke stub shaft in that spindle in past?
« Reply #797 on: April 04, 2018, 09:30:43 AM »
car has eaten 2 spindles from yukon chromo explosions before, but not since 300M rcvs.  also they just get mangled in the spindle bearing area not really damaged structurally.  this one just plan broke from impact
« Reply #798 on: May 16, 2023, 06:27:07 PM »
dropped off for some prep, mostly he has been fighting dragging rear brakes
got fresh fuel lines and filter
shortened pushrod on brake booster
hooked back up right rear brake line
flushed system and bleed with DOT5.1
welded up exhaust cracks
bolt check
changed out loose 7/8" top lock on steering
should be prepped for AOAA Memorial weekend
« Reply #799 on: August 03, 2023, 08:25:13 PM »
U4 race carnage
driver side collector gasket vacated
2 broken limit straps front driver side
broken wheel
2 broken 14 bolt spindles
1 broken front drive slug cap bolt
broken long side inner 300m RCV shaft
broken swaybar arm/swaybar mushed spline
co driver no transmit out on coms
one tool bag lost
rough race.
« Reply #800 on: August 05, 2023, 07:44:02 PM »
Dang
« Reply #801 on: October 16, 2024, 04:34:16 PM »
well the axle that was a brand new build after the last post above lasted 40 miles and then he hit something center mass at pace and broke the axle housing.
1410 yoke trashed, gear set trashed, housing junk.
fresh housing stripped and prepped, good parts removed from old axle.  ready to start welding and assembly tomorrow.
« Reply #802 on: October 16, 2024, 09:37:49 PM »
Quite the hit. Wow
« Reply #803 on: October 19, 2024, 12:39:45 PM »
new rear axle done
ready for hallowheeling minus ubolts to install the rear driveshaft
« Reply #804 on: October 21, 2024, 12:43:40 PM »
speedy!
« Reply #805 on: October 23, 2024, 09:37:00 PM »
Matt stopped over after work and we wrapped up and prepped last items
40s swapped on
rear shaft installed
front shaft serviced, 2 new 1350 caps
full grease job
90degree grease fittings installed on sway bar (annoyed me for 12 years)
C pillar cracked tube fixed
ready to load for hallowheeling minus some fuel
« Reply #806 on: February 24, 2025, 04:20:34 PM »
pulled out of winter storage today
front torn down to inspect and install new RCV shaft
front gear set missing a few teeth bah
sad when it still has the pattern paint on it from whenever i set it up.
« Reply #807 on: February 24, 2025, 04:33:12 PM »
How does that happen?
« Reply #808 on: February 24, 2025, 04:40:48 PM »
i think it was a new setup 2 races and a rec wheel trip.  I clean an prep gear sets very well, and actually use oil based paint for marking compound, so not really surprised its still in there.  All preloads and bearings tight still.   could be lack of break in but most likely just impact failure.  Ill try to add even more preload for next setup.  he has a spare gear set on the shelf coming tomorrow am.
matts comment was "probably shouldnt have tried to finish the last race in FWD"  lol
« Reply #809 on: February 25, 2025, 06:25:36 PM »
new gear set installed in the front diff
RCVs fully disassembled, cleaned, re greased, new square edge clips inner shafts, new round edge clips outer shafts.
new short side inner and cage/balls
2 heims on front axle changed
