Author Topic: matts buggy build  (Read 225360 times)
Re: matts buggy build
« Reply #555 on: September 03, 2014, 08:19:47 AM »
from wayne
remote fuel cell fills not required unless you can't refuel safely without one.
I am a safe fueler! Lol
Almost impulse bought a 11 gal Hutchinson race can from Ruff Stuff yesterday.
« Reply #556 on: September 03, 2014, 01:45:12 PM »
Those are huge and Prob a back breaker.
« Reply #557 on: September 03, 2014, 01:53:17 PM »
They're probably the only way to go when you want to take on 10-20 gallons at a remote pit though. Can you imagine trying to put 3-4 5 gallon gans in quickly? I'd rather heave-ho an 11 twice. Best with a drylock fitting so you can't overflow, but that's a lil too bling for us, I think.
CJ
« Reply #558 on: September 03, 2014, 02:08:23 PM »
We have the ranger for remote pit gas transport. May be able to rig up a tower in the back for fuel dump? Probably not enough time to fab.
« Reply #559 on: September 03, 2014, 02:15:36 PM »
we are talking for KOH no KY
KY we plan on bringing 32 gal in the cell should be good for all weekend
« Reply #560 on: September 03, 2014, 02:31:47 PM »
She is excited for both races... can you tell?
Lol. ;)
CJ
« Reply #561 on: September 03, 2014, 02:34:10 PM »
So what you're saying is I have plenty of time to fab up a fuel tower  ;)
« Reply #563 on: September 03, 2014, 02:43:25 PM »
Nothing to it.
« Reply #564 on: September 04, 2014, 01:34:11 AM »
your chassis gussets are full welded and your window nets are re drilled because it takes a legit 15 min per cut on the band saw to hawg through 2 3/8" 7075  X4 tonight
« Reply #565 on: September 04, 2014, 07:44:44 AM »
Multi tasking at it best.
I will have some time Friday Saturday and Sunday to lend a hand if necessary.  My only real project is to SQUEEZE the ranger in the back of the RV.
It feels strange not having to work on the buggy before a trip.
« Reply #566 on: September 04, 2014, 09:08:07 AM »
Whoa you were up late! Thanks though! A 10 mm union and some fuel hose I'll be able to pass tech!
« Reply #567 on: September 09, 2014, 09:24:28 AM »
cracked rear truss welds fixed
« Reply #568 on: September 23, 2014, 08:49:30 AM »
front CO welded back together, its no longer a remote res   ::)
tightened up limit straps about an inch
needs assembly, then 5.3 stumble fix, then left side trailer door fix...
« Reply #569 on: September 23, 2014, 09:41:53 AM »
another failing trailer door?
Sucks it's still stumbling.
Fitting broke on the remote? I have a spare from my bad shock that I'm not swapping onto my right front any time soon if the remotes and fittings are the same. or if it's a hose issue that's probably a straight up spare.
