Author Topic: matts buggy build  (Read 225279 times)
Re: matts buggy build
« Reply #540 on: August 06, 2014, 08:10:32 AM »
Back to my buggy..., ;p lol
Gonna run a 160 thermostat since I wheel in the winter. Will be interesting to see how yours does mike mike with just the restricter plate.
« Reply #541 on: August 06, 2014, 11:47:52 AM »
does the PCM look at the coolant temp when fuel mapping on these engines?
I know with my TBI engine coolant temp plays a big part on the fuel mapping.
« Reply #542 on: August 14, 2014, 12:00:38 PM »
Apparently I was full of shit poo-pooing bushings on the shock eyes.
http://www.pirate4x4.com/forum/general-4x4-discussion/985055-alternative-wobble-stopper-2.html
« Reply #543 on: August 14, 2014, 01:03:53 PM »
that was a really pain full read.
matts buggy build
« Reply #544 on: August 21, 2014, 01:18:24 PM »
Got my work cut out for me if I want to do BB Blowout in KY. 20 days!!
8k Trailer Axles?
Check u joints in tow truck..., order spares
Fix tuner? Meh
Clean out/organize trailer
Tool box storage and cabinets in trailer
U4
-Meet Weight spec
-Rear bump frame strengthening for jumps!
-Lower hood line to see competitors!
-Nerf bars to nerf competitors!
-top locks
-4 side fuel vent
-E brake
-Reflective tape on rear
-Sway bar
-New Tires or use vulc'd patched MTRs
-Two new method wheels or use walkers
-3/4 ton front brake kit
-Super joint grease and gun
-Shock and bump pressure check
-New side tins
-Fix brake booster leak
-Add numbers to front and rear of car
« Last Edit: August 21, 2014, 01:35:51 PM by rockaholic »
« Reply #545 on: August 21, 2014, 01:34:42 PM »
fuel cell baffling/foam to meet tech...
« Reply #546 on: August 21, 2014, 01:35:27 PM »
both need brake locks
« Reply #547 on: August 21, 2014, 01:37:05 PM »
Mike could I try out your Simpson neck restraint for this race? Think I may get yours instead of a Hans device.
« Reply #549 on: August 21, 2014, 02:01:32 PM »
mechanical line lock seems pretty sweet!
« Reply #550 on: August 21, 2014, 02:06:23 PM »
ya the two i have are stainless now
« Reply #551 on: August 26, 2014, 11:40:56 PM »
scaled at 4620 1/4 tank fuel stripped of spares on treps tonight   :o
« Reply #552 on: August 27, 2014, 06:50:12 AM »
Wow
« Reply #553 on: August 27, 2014, 08:29:06 AM »
Boo!
« Reply #554 on: September 03, 2014, 08:13:22 AM »
from wayne
remote fuel cell fills not required unless you can't refuel safely without one.
