Author Topic: matts buggy build  (Read 225340 times)
Re: matts buggy build
« Reply #495 on: May 08, 2014, 01:48:59 PM »
What CI/turn orbital though? Load reaction?
I don't know what my orbital is.
Smike found it on Rausch forum and I bought it for $80.00 ;) hooked it up and works fine.
I understand the difference between stress and abuse of rec wheeling vs racing.
What is a load reaction orbital?
Nah nevermind.
 I'll let the engineers sort it out.
I'll just go back to rec wheeling.
Best of luck tjis weekend guys.
Damn you guys and you're lucky cheap orbitals ;p
« Reply #496 on: May 08, 2014, 01:54:29 PM »
I'd try another orbital at this point.  You can always sell it.
« Reply #497 on: May 08, 2014, 01:55:58 PM »
I'm on my second orbital and would like to keep it as it was $500 ;p
« Reply #498 on: May 08, 2014, 01:57:41 PM »
I didn't know you got another one.  Is this one legit?
« Reply #499 on: May 08, 2014, 01:59:13 PM »
Lol yeah it's a Eaton unit from PSC (who said id have no issue using it in conjunction with a Saginaw can o ham pump)
« Reply #500 on: May 08, 2014, 02:00:37 PM »
Load reaction as well which fixed the pump shaft shearing prob
« Reply #501 on: May 08, 2014, 02:07:39 PM »
Pressure. Gauge.
« Reply #502 on: May 08, 2014, 02:10:59 PM »
yeah time some data logging!
« Reply #503 on: May 08, 2014, 02:23:22 PM »
Can of ham with stock housing?
Or with remote res?
« Reply #504 on: May 08, 2014, 02:28:22 PM »
Remote res and stock res
« Reply #505 on: May 08, 2014, 02:44:43 PM »
And remote res plumbed to stock filler. It's not fluid starved.
« Reply #506 on: May 08, 2014, 03:12:08 PM »
That was my initial setup when I first converted to full hydro.
Same as smike. Stock saginaw housing but I put a remote reservoir in the system.
Would constantly suck air from the stock housing cavity and burn out the pump.
After 2 bulls hit reman pumps to get me going again I broke down and called PSC.
Lance said never use the stock housing with the remote reservoir. It needs to be the full sealed housing with high pressure line and return below the top of the housing.
Also ended up having to place large hose clamp around entire housing with RTV to ensue no air leaks.
Been working great ever since.
I'm just trying to help.
I'm not trying to tell you what to do.
« Reply #507 on: May 08, 2014, 03:13:22 PM »
Since rebuilding my system they have introduced a new design reservoir. In and out at the bottom of the can...
« Reply #508 on: May 08, 2014, 03:17:19 PM »
I think all 3 cars have essentially the same can o ham + remote, and I think all are using the stock return line fitting on the can.
I don't think there's an orientation difference between 571 and 928. Not sure what 572 looks like off the top of my head.
« Reply #509 on: May 08, 2014, 05:09:29 PM »
But what about the filler neck?
