Author Topic: matts buggy build  (Read 225336 times)
Re: matts buggy build
« Reply #450 on: March 04, 2014, 10:00:22 PM »
572's motor has lost 15psi of hot oil pressure since i have owned it.  id get a 10 or 12 psi switch instead of 20.  my 20 blinks at hot idle.  its annoying.
« Reply #451 on: March 04, 2014, 10:01:13 PM »
Haha I thought so!
« Reply #452 on: March 10, 2014, 10:13:57 AM »
Trans temp sensor working, interested to see how warm she gets at Rausch in some go fast and big uphill rock trails. Going to be hitting it hard after to make the race 4/12!
« Reply #453 on: March 17, 2014, 09:08:07 AM »
Winching in the comp course with no winch brake or brakes = not fun
« Reply #454 on: March 17, 2014, 09:52:16 AM »
and a high stall converter that stalls the engine when rolling backwards doesnt help either.
« Reply #455 on: March 17, 2014, 09:55:46 AM »
Yeah fail on that too. Frustrated
« Reply #456 on: March 17, 2014, 09:59:04 AM »
id be more agervated that the steering system is 100% the same as 572 and 571 and it continues to fail pumps.
Should give a pump to gifford to take apart and figure out whats going on.
« Reply #457 on: March 17, 2014, 10:00:09 AM »
I read up last night have some things to try with existing system.
« Reply #458 on: March 26, 2014, 03:15:38 PM »
Steering system update:
Found metal flakes in fluid (needs flushing) I assume this is from the pump I wore out with my old non load reaction orbital. Never flushed for new pump/load reaction orbital put on.
Going to add a filter and a non remanufactured pump with something better than ATF as a fluid.
Some of you run the Tractor Supply stuff? Anyone have specs or details on what type? Heading there tonight before the FLX meeting.
matts buggy build
« Reply #459 on: March 26, 2014, 03:18:00 PM »
Adding copycat larger MC for added braking like 572, dropped my brake booster and ruined sealing surface. $130 on summit back up if J&J doesn't have any this weekend. Possible test and tune this Sunday at Rausch! My brother Joe is in to go!
« Reply #460 on: March 26, 2014, 03:21:09 PM »
Also smike came up with a good idea last night for lower link anti twist bars from the lower links to the rear axle housing, we have materials an rod ends to get it done as well!
« Reply #461 on: March 26, 2014, 09:45:15 PM »
http://m.youtube.com/watch?v=bZwrtf-BR7I
I remember this video from some training hours a while back...
« Reply #462 on: March 27, 2014, 10:39:26 PM »
Cavitation video
http://www.youtube.com/watch?v=-7d-OscIGwo
schematic shows how the return fluid goes into the reservoir after the cooler.
This allows any air to rise to the top.    Air free fluid is pulled from the bottom of the reservoir into the pump.
reservoir should be the highest point of the system.
« Last Edit: March 27, 2014, 10:52:24 PM by gif »
« Reply #463 on: March 27, 2014, 11:20:11 PM »
P185 pump is what we want
P185 was available in 97-99 chevy Medium Duty trucks with a 6.5 diesel.
most "P" series saganaw pumps will put out between 3 and 5 gpm depending on flow mod and pump shaft speed
keep in mind there are different stile P pumps there is the p132 and the p185
the 132 is the every day run of the mill p then the 185 has the larger ring and rotor (it pumps more oil) which is like the "1400 pump" from PSC
there is only one true way to tell the difference between a P132 and a P185 and that is to compare the ring and rotor (the P185 ring is .200" taller)
***  most re builders seem to use the lower flow pumps in applications that were factory high flow ***
top pic is 185    bottom is 132
Hydroboost brakes "P" style saginaw pump with attached reservoir (1980 Chevy K30 4x4 1-ton with 350c.i. and Hydroboost brakes)
« Reply #464 on: March 28, 2014, 12:06:51 PM »
I figured you guys would have been running "TC" style pumps not the "P" pumps
Is there a tc pump that flows as good as the 185 pump?
