Author Topic: matts buggy build  (Read 225320 times)
Re: matts buggy build
« Reply #435 on: January 28, 2014, 01:43:19 AM »
vents run
hood pin'd
badass radio box made
axle tie downs / jack points welded on
tool bag ties welded in
front upper dash bolted in
« Reply #436 on: January 28, 2014, 01:44:36 AM »
All Wiring finished! Race mix and trail mix flash drive being created now!
« Reply #437 on: January 28, 2014, 05:31:18 PM »
« Reply #438 on: January 29, 2014, 10:39:14 AM »
« Reply #439 on: January 29, 2014, 10:40:25 AM »
Dean Benner is having Viper coil bring two 300 16"x3" coils to the lakebed 8)
« Reply #440 on: February 11, 2014, 10:12:01 AM »
Car holds up pretty good in the whoops
needs high range and better air to radiator- runs hot
trans gage sender needs a ground
front shaft carrier bearing needs real fix / relocation / better steel
skid got peeled, winch cable got shorter.
« Reply #441 on: February 11, 2014, 10:17:15 AM »
Can't see over hood...
« Reply #442 on: February 11, 2014, 10:52:35 AM »
install a camera
« Reply #443 on: February 11, 2014, 10:57:54 AM »
And done.., ;p
« Reply #444 on: February 11, 2014, 11:13:45 AM »
haha
changed out rears to 200/300 on lake bed also
matts buggy build
« Reply #445 on: February 26, 2014, 11:33:07 AM »
RCROCS 1 Prep (Ideally lol)
Order goggles
Bumpers
Outerwear on air filter
Hood line lowered (haha)
Wire casing and clean up
Window nets
Spare Fluid box mounted
Trans vent and containment
Low oil pressure unit
Add tube to winch fairlead
Fix winch wiring, lock and hold issue
Tack Weld front DS yoke
T case shifters
Tree bars
37" tires with new wheels
Tool organized in one bag
Handle bars
Numbers
Go pro mount
« Last Edit: March 10, 2014, 10:15:11 AM by rockaholic »
« Reply #446 on: February 26, 2014, 11:36:49 AM »
Treps not working for you?
matts buggy build
« Reply #447 on: February 26, 2014, 11:37:55 AM »
I'm buying 9 37" GY Wrangler MTR Kevlars to beat on for go fast only racing.
Treps are awesome but excessively heavy and too large for woods racing. I'll prob only use them for Dirt Riot in Shamokin.
« Reply #448 on: February 26, 2014, 11:39:01 AM »
much less rocks on course this year
smaller tires help power to ground / handeling
shredding a couple BFG's much nicer than treps
« Reply #449 on: March 04, 2014, 12:17:46 PM »
http://m.summitracing.com/parts/reb-140-1280
Whole low oil pressure light system for under $20?
