Author Topic: TFT ZJ Style  (Read 45365 times)
Re: TFT ZJ Style
« Reply #105 on: April 17, 2013, 08:42:31 AM »
those are comming from a guy that wanted to run 42" TSLs on I90, and did not like the tire strobbing up and down 6" at 45mph
Re: TFT ZJ Style
« Reply #106 on: April 17, 2013, 08:54:10 AM »
I'd think 4-6 oz should be closer...
Re: TFT ZJ Style
« Reply #107 on: April 17, 2013, 08:58:19 AM »
I dont think it will make a difference.
How does it feel slow? Does if feel like something is out of round driving at 5mph?
Re: TFT ZJ Style
« Reply #108 on: April 17, 2013, 09:03:55 AM »
consensus online is too much doesnt hurt...
feel good at slow speeds. as you climb 15-25 it gets progressively worse. feels like i can induce DW at anything over 30-35 (speedo isnt working)
Re: TFT ZJ Style
« Reply #109 on: April 17, 2013, 09:27:32 AM »
Have you double checked all the steering and suspension joints for tightness? That won't help the 'horse' feeling, but could definitely contribute to DW.
Re: TFT ZJ Style
« Reply #110 on: April 17, 2013, 09:33:16 AM »
yeah i check them all when adjusting the toe. everything was good.
Re: TFT ZJ Style
« Reply #111 on: April 17, 2013, 09:33:24 AM »
As you said, doesn't hurt. But if it takes that much weight there's something else wrong there. Maybe the tire has been worn to out of round by a poorly set up vehicle before, or when airing up the beads didn't seat properly which believe it or not happens a lot. There should be a line just larger than the rim all the way around the bead, make sure its equal distance from the rim all the way around. Give them all a good spin and make sure there isn't more then a couple 32nds  of movement up or down and side to side. If all of that checks out, I'd move on to suspension and steering
Re: TFT ZJ Style
« Reply #112 on: April 17, 2013, 09:41:03 AM »
good info. i'll check that out. thanks
Re: TFT ZJ Style
« Reply #113 on: April 17, 2013, 10:54:19 AM »
You sure the rims are not bent?
Re: TFT ZJ Style
« Reply #114 on: April 17, 2013, 10:56:56 AM »
no, I'm not. I need to check that out too. they are troy's old H1s
Re: TFT ZJ Style
« Reply #115 on: April 17, 2013, 11:00:18 AM »
those are not allowed at big dogs!
Re: TFT ZJ Style
« Reply #116 on: April 17, 2013, 11:06:57 AM »
They're screwed together with plates now, no more of those shenanigans.
Re: TFT ZJ Style
« Reply #117 on: April 17, 2013, 11:08:25 AM »
haha
TFT ZJ Style
« Reply #118 on: April 17, 2013, 05:09:25 PM »
31s and 5.13s are fun. Needs a line lock.
Seemed to really help the vibes/DW. Took it to 65.
TFT ZJ Style
« Reply #119 on: April 18, 2013, 08:21:37 PM »
Rear axle on jackstands. In drive tires spinning slow. Tread surface runout upwards of 1/2".
