Author Topic: TFT ZJ Style  (Read 45355 times)
TFT ZJ Style
« Reply #75 on: April 15, 2013, 09:05:46 AM »
Did work
Re: TFT ZJ Style
« Reply #76 on: April 15, 2013, 09:26:42 AM »
exhaust is looking pimp.
harry beat you to the test drive though :(
Re: TFT ZJ Style
« Reply #77 on: April 15, 2013, 09:29:30 AM »
True, but he has a correct length rear shaft and confirmed months ago that his front locker works. So kinda fail on my part
TFT ZJ Style
« Reply #78 on: April 15, 2013, 08:40:55 PM »
Drove this hog tonight. She is not pleased with speed. Feels like riding a fucking horse. Looking at the tires they seems really wonky. Weird.
Also got death wobble. Nice.
TFT ZJ Style
« Reply #79 on: April 16, 2013, 08:44:36 AM »
How's your alignment, particularly caster?
Re: TFT ZJ Style
« Reply #80 on: April 16, 2013, 08:57:46 AM »
looks like pinion is kicked up way to high in front and she has about 2" of toe in
need more info sir
Re: TFT ZJ Style
« Reply #81 on: April 16, 2013, 09:03:24 AM »
i need to check on those things tonight. i had set caster at +5*, but need to verify. what would you set toe at? around 1/8" toe in?
and try running higher pressure in the tires. forgot i had just thrown in 22psi to make sure they were holding air. tires have BBs to balance
Re: Re: TFT ZJ Style
« Reply #82 on: April 16, 2013, 09:05:28 AM »
That should be a good starting point. Set mine there by tape and factory spec alignment on the machine never moved it .
Re: TFT ZJ Style
« Reply #83 on: April 16, 2013, 09:10:30 AM »
maybe its the pic but it looks like you are at -5.... upper kingpin is behind lower right
1/8 to 3/8" should be fine for 37" at the tread
Re: TFT ZJ Style
« Reply #84 on: April 16, 2013, 09:18:39 AM »
upper is behind lower. but i will verify tonight. ive fawked it up before...  ::)
TFT ZJ Style
« Reply #85 on: April 16, 2013, 09:40:19 AM »
Factory caster is usually between 0 and 3 degrees with respect to the cast-in perch. Pinion often has to be tipped down a bit at ride height to get the 5-7 degrees you want with big tahrs
Re: TFT ZJ Style
« Reply #86 on: April 16, 2013, 09:42:45 AM »
caster? pinion angle?  what are these thing you speak of :D
Re: TFT ZJ Style
« Reply #87 on: April 16, 2013, 09:49:26 AM »
I noticed your healthy pinion angle last year hahaha
Re: TFT ZJ Style
« Reply #88 on: April 16, 2013, 10:30:16 AM »
Just the man i was looking for!!
can you look at the wiring diagram for my locker? (page 11)
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_128304.pdf
can i just supply a hot and return to it and be ok? or does it need some voodo back box magic
I'm  talking like take the 2 wires coming out of the locker and splice on a cigarette plug and plug it in when i want the front locked.
Edit: i think the answer is yes. they recommend a relay, but thats wouldn't really be necessary, right?
« Last Edit: April 16, 2013, 10:40:54 AM by KingtheZJ »
Re: TFT ZJ Style
« Reply #89 on: April 16, 2013, 10:46:46 AM »
what is this a hot water base board were installing here?  ;D
in the end, yes.  a relay is just less load to run thought the switch.  looks like theres a diode in there for one last deference on s surge. do you have this harness?
what kind of bush mechanictry is this?  put a fuse and a switch in at least...
