Author Topic: TFT ZJ Style  (Read 45321 times)
Re: TFT ZJ Style
« Reply #60 on: April 03, 2013, 03:25:54 PM »
Thinking a little more unusual.  Maybe S10 or Colorado based?  Maybe.  :-X
Re: TFT ZJ Style
« Reply #61 on: April 03, 2013, 03:28:50 PM »
Good idea, Mark. I love my XJ, but frames.... mmmmmmm.
Re: TFT ZJ Style
« Reply #62 on: April 03, 2013, 03:32:50 PM »
MUST have a frame.  Not dealing with all the extra bracing you unibody guys deal with.  Back on topic...
Re: TFT ZJ Style
« Reply #63 on: April 07, 2013, 07:08:42 PM »
done:
rear coil buckets
rear shock mounts
rear brake lines/bleed
swap out front long side to chromo shaft and spicer joint
figure out how the fuck to install these damn warn lockouts.
weld on front shock mounts
swap out tcase for 231 w/ sye
rear driveshaft
to do:
bleed rear brake lines
gusset/ support upper link brackets
close floor
fill case
fill front diff
front cover?
Dodge van MC?
front driveshaft
tcase skid
align front end
adjust drag link
overfill trans
address stalling (new battery?)
tie up downstream o2/fix wires
optional:
re bend pitman arm
pull hitch/ fab rear bumper
trans x/member
trans skid
custom y pipe and exhaust
« Last Edit: April 09, 2013, 10:09:54 PM by KingtheZJ »
Re: TFT ZJ Style
« Reply #64 on: April 08, 2013, 08:56:53 AM »
Nice. Did one Rausch trip prove that stalling and O2 wires were related issues?
TFT ZJ Style
« Reply #65 on: April 08, 2013, 08:24:23 PM »
This better be worth it. Got an ear full of trans fluid getting this guy out.
TFT ZJ Style
« Reply #66 on: April 08, 2013, 09:40:28 PM »
Is that my old sye?
TFT ZJ Style
« Reply #67 on: April 08, 2013, 10:02:55 PM »
Is that my old sye?
Yeah buddy!
Shoving the case up an inch. Almost clears the bottom of the frame rail. Extending a front double cardan shaft and its gonna work perfect.
For my reference before I forget
Existing shaft 31"
Lengthen 6.25" to 37.25"
Gives .5" clearance of bottoming slip at full bump
Shaft length at full droop is 38.5
Check double cardan clearance at full droop
Check pinion angle can be adjusted properly and upper links can get long enough
TFT ZJ Style
« Reply #68 on: April 10, 2013, 10:52:33 PM »
Trans crossmember. Pushed the trans/ case up 1.5". Increased ground clearance 2".
Re: TFT ZJ Style
« Reply #69 on: April 11, 2013, 07:18:14 AM »
Possible to put a bend in the square tube to get it flush with the side plates?
Re: TFT ZJ Style
« Reply #70 on: April 11, 2013, 07:56:21 AM »
front driveshaft clearance and exhaust clearance are about as tight as they can be. I could have notched the 2x2 out for them, but the tcase skid will have to drop down to that height anyway.
TFT ZJ Style
« Reply #71 on: April 11, 2013, 10:11:21 PM »
Installed
TFT ZJ Style
« Reply #72 on: April 11, 2013, 10:14:45 PM »
done:
rear coil buckets
rear shock mounts
rear driveshaft
front driveshaft
trans x/member
to do:
close floor
fill case
fill front diff
front cover?
Dodge van MC
tcase skid
align front end
adjust drag link
overfill trans
Front limiting straps
optional:
re bend pitman arm
trans skid
Rear bumps
Re: TFT ZJ Style
« Reply #73 on: April 12, 2013, 07:21:58 AM »
optional:
trans skid
Optional?  Seems important.
Re: TFT ZJ Style
« Reply #74 on: April 12, 2013, 10:16:36 AM »
An extra 1/4" of clearance without that pesky steel in the way ;D
