Author Topic: TFT ZJ Style  (Read 45367 times)
Re: TFT ZJ Style
« Reply #120 on: April 18, 2013, 08:29:54 PM »
O_o no good!
Re: TFT ZJ Style
« Reply #121 on: April 18, 2013, 09:02:39 PM »
to do:
gusset/ support upper link brackets
fill front diff
front cover?
Dodge van MC
tcase skid
adjust drag link
overfill trans
tie up downstream o2/fix wires
finish exhaust
Front limiting straps
trans skid
wire up locker
optional:
re bend pitman arm
pull hitch/ fab rear bumper
Rear bumps
TFT ZJ Style
« Reply #122 on: April 18, 2013, 10:06:14 PM »
Double checked tires squarely seated and bead indicators and wheels are running true?
TFT ZJ Style
« Reply #123 on: April 20, 2013, 05:16:41 PM »
$50 Craigslist street 35s solved all my problems. She screams at 70mph with 5.13s hahaha
TFT ZJ Style
« Reply #124 on: April 20, 2013, 05:19:08 PM »
to do:
fill front diff
front cover
tcase skid
overfill trans
trans skid
wire up locker
optional:
re bend pitman arm
Rear bumps
Radiator support
TFT ZJ Style
« Reply #125 on: April 21, 2013, 09:46:13 AM »
I don't see "fix 37s" on the list
Good to 100% confirm tires are the culprit.
TFT ZJ Style
« Reply #126 on: April 24, 2013, 11:12:58 AM »
This hog popped a CEL this morning on startup and would fall flat on its face if you let off the gas. Scanner said faulty IAC and had me panicking. JeepForum pulled through with a PCM reset and she was up and running.
Re: TFT ZJ Style
« Reply #127 on: April 29, 2013, 11:15:43 AM »
im very pleased with how this did at BD.
SO fun with 35s and 5.13s on the way home in the rain. i think i'll be driving this more often now.
Re: TFT ZJ Style
« Reply #128 on: April 29, 2013, 12:11:29 PM »
Thanks for the turn behind the wheel on V.
A+++. Would wheel again.
Re: Re: TFT ZJ Style
« Reply #129 on: April 29, 2013, 12:40:45 PM »
Mike- you do have all the parts to clone it...
« Reply #130 on: April 29, 2013, 01:25:12 PM »
Excellent point.
What's your tire plan Spencer?
Re: TFT ZJ Style
« Reply #131 on: April 29, 2013, 01:35:43 PM »
they really worked quite well. with 10psi and a fully functional front locker i think they would be good. going to give them another try.
Re: TFT ZJ Style
« Reply #132 on: April 29, 2013, 02:07:50 PM »
maybe 15 in the fronts. that sidewall just fell apart post-puncture.
Re: TFT ZJ Style
« Reply #133 on: April 29, 2013, 04:07:26 PM »
remember, they are no KRT or bogger....
Re: TFT ZJ Style
« Reply #134 on: April 29, 2013, 04:20:46 PM »
Ran my old TSLs at 8-10 all day long. Was running the 36s all weekend at 8, figured I was overcoming the E range sidewall and relatively hard compound.
