Author Topic: TFT ZJ Style  (Read 45341 times)
TFT ZJ Style
« Reply #135 on: May 22, 2013, 09:09:37 PM »
37s and 14b tubes now look "normal sized" to me
Re: TFT ZJ Style
« Reply #136 on: May 23, 2013, 07:35:03 AM »
More to the point, D30 shafts look completely useless
Re: TFT ZJ Style
« Reply #137 on: June 03, 2013, 10:50:17 AM »
h1 wheels are bent. bah
Goodyears are chunked and sidewalls all cut up. garbage tires for pointy rock terrain (read:east coast)
front end disassembled for locker replacement. Open carrier welded up and ready for dirty gear setup.
this guy needs bottom end engine seals BAD. been putting that off for 4 years.
Re: TFT ZJ Style
« Reply #138 on: June 03, 2013, 11:45:49 AM »
need more pressure
id race the snot out of them at 25psi for line mt
Re: TFT ZJ Style
« Reply #139 on: June 03, 2013, 12:00:39 PM »
were at 8psi for 4 hours at BD, then the one got cut. they have all been at 20psi since.
Re: TFT ZJ Style
« Reply #140 on: June 03, 2013, 07:17:59 PM »
They are shitty and worthless
Re: TFT ZJ Style
« Reply #141 on: March 25, 2014, 09:40:26 AM »
parts list for hydro assist
3/8" X 36" JIC 6F X JIC 6F 4000 PSI HYD HOSE
Item Number: 930-2236
1.5X8X1 DA HYD CYL SWIVEL EYES
Item Number: 9-7258-8
JIC 6M x 1/4 NPTM 45 ELBOW
Item Number: 9-2503-6-4
JIC 6M TO SAE 6M 45 ELBOW
Item Number: 9-6802-6-6
Re: TFT ZJ Style
« Reply #142 on: March 25, 2014, 09:57:21 AM »
Re: TFT ZJ Style
« Reply #144 on: October 28, 2015, 09:24:15 AM »
   Terrain Suspension Seat
Black Velour
Part Number # 942-80-1620-61
how do these seats seem to hold up?
Re: TFT ZJ Style
« Reply #145 on: April 14, 2016, 11:30:20 AM »
CJ
Re: TFT ZJ Style
« Reply #146 on: April 14, 2016, 11:46:54 AM »
from teh Q&A:
"It will bend 1 5/8" tubing, but it will only handle up to 0.090 wall tubing."
Re: TFT ZJ Style
« Reply #148 on: April 14, 2016, 07:27:27 PM »
The last one is what I got works good
Re: TFT ZJ Style
« Reply #149 on: September 02, 2016, 12:20:15 PM »
Shooting to have this on the road and ready for the Autumn Adventure Sept 24th.
Needs:
Hydro assist lines secured
Check diffs
Check trans
Slime slow leak tire
Check possible leaking brake line
Check Alignment
Check Control arm bolts
Rear Driveshaft vibration?
Oil change
Quiet down exhaust?
Transfer case swap to hopefully fix howling above 40mph
address need for lockouts vs flanges. Is rolling all day in 2wd ok?
