Author Topic: Time for Tons  (Read 126262 times)
Re: Time for Tons
« Reply #390 on: February 25, 2015, 01:21:15 PM »
o lord what a pain and leak path
good luck with that sir- you are braver than I
Time for Tons
« Reply #391 on: February 25, 2015, 01:36:55 PM »
They will get slathered with bead sealer. It has definitely been more work than I anticipated but I'm committed at this point. Couldn't bring myself to spend $1k+ on 16" beadlocks when I know 17s are in my future. Know a few people personally who have had good luck with them. I'm aware Erik is not one of them :)
Re: Time for Tons
« Reply #392 on: February 25, 2015, 01:40:27 PM »
Ryans sucked the worse
Jeff and Gif deal with them leaking, slime fixed most.
Re: Time for Tons
« Reply #393 on: February 25, 2015, 04:35:46 PM »
Slime fixed all my leaks.
Re: Time for Tons
« Reply #394 on: February 25, 2015, 04:58:10 PM »
I did not do mine, I bought them already done with the tires on them.
I remember that the coning was the worst part of it. You really do need anti-coning rings welded on as well.
Re: Time for Tons
« Reply #395 on: February 25, 2015, 06:22:54 PM »
Mine came with the tabs that bend up for anti-coning.
Re: Time for Tons
« Reply #396 on: February 27, 2015, 10:48:36 PM »
3 more to go... We'll see how this one holds air tomorrow
Re: Time for Tons
« Reply #397 on: February 28, 2015, 09:07:58 AM »
Looks great but I love orange!
What did your bead width measure when completed?
Re: Time for Tons
« Reply #398 on: February 28, 2015, 10:19:26 AM »
Looks like I went from 30 to 25 psi last night looks like slime is in my future.
For Mark:
Re: Time for Tons
« Reply #399 on: February 28, 2015, 10:58:37 AM »
Thank you
Re: Time for Tons
« Reply #400 on: March 01, 2015, 04:57:24 PM »
Re: Time for Tons
« Reply #401 on: March 01, 2015, 05:06:01 PM »
I think you need a taller garage!
Looks sweet!
Enginerd
  • Jr. Member
Re: Time for Tons
« Reply #402 on: March 01, 2015, 05:46:51 PM »
Did you use top locks or regular nuts?
I welded up a set last fall from AtoZ, because I too couldn't justify the cost of new.  Mine will leak down about 5 lbs over the course of 2 weeks, which is easy enough to deal with.  Will probably give all of the bolts another 1/2 turn before spring hits.
Re: Time for Tons
« Reply #403 on: March 01, 2015, 06:09:51 PM »
Yep, they came with top lock nuts. The last two I did haven't leaked at all yet... Second one had a leaky valve stem and the first lists 10psi since Friday night.
Re: Time for Tons
« Reply #404 on: March 01, 2015, 06:24:35 PM »
Did you do anything with the valve stem?  Thinking of moving mine...
