Author Topic: Time for Tons  (Read 126262 times)
Re: Time for Tons
« Reply #375 on: January 06, 2015, 04:21:11 PM »
My junk is listed. We'll see what happens.
Re: Time for Tons
« Reply #376 on: January 06, 2015, 04:29:39 PM »
stretch it!
Re: Time for Tons
« Reply #377 on: January 06, 2015, 04:35:47 PM »
Nah. I'm gonna throw too much money at a D300 I think.
Arie, did you have a D300 with a 4:1 kit in it already?
Re: Time for Tons
« Reply #378 on: January 06, 2015, 04:38:49 PM »
It will be fine.
It will still be cheaper than spending min 2500 on an atlas.
Time for Tons
« Reply #379 on: January 11, 2015, 06:13:04 PM »
Spent this weekend pulling leaves with broken weldnuts inside the rails. Fun. Broken from flexing of outer bracket, not from attempting to remove bolt. This needed to be done two years ago.
Spare me the fluxcore and 4 link comments! Will probably add another brace of some kind on the front. Not sure what I want it to look like yet and it can be added later.
Time for Tons
« Reply #380 on: January 25, 2015, 02:55:10 PM »
Ordered these. I like the built in anti-coning feature. Going to weld these to some stock Ford 16x7 steelies. (courtesy of Troy)
https://totalmetalinnovations.com/index.php?main_page=product_info&cPath=130&products_id=384&zenid=a1496435d98b8f0ecdf3541096085ac3
Decided I'm going to buy the $400 output for my case. I can't find anyone who is having issues with breaking front outputs on their 20. Found a local guy who does cryo treating, haven't decided if I think that's worth it for the front. Estimating it will run around $20.
Got an S10 pack someone was using for the same amount of lift in another XJ. Same dimensions as the Dodge van leaves I had in there that give a nice shackle angle but the S10 leaves have the center pin 3" further back. So I added about 2" more of stretch. The AA 32 spline output is about 1.5" longer so this works perfectly for letting me continue to use stock XJ front driveshafts.
The S10 packs are significantly less HD than the van leaves. I'm hoping this helps with flex a little, but I was worried about axle wrap so I bought some brackets and bushings from Ruff Stuff and pieced together a traction bar from steel and old heims I had laying around. Went with the "slip and twist" design to save ground clearance. 3/16" wall 2" square tube with 1-5/8" 1/8" wall inside. Made the upper link mount long to hopefully help combat bending. Hopefully it doesn't bend. Had to scooch the exhaust over a little bit to clear it so I'm going to need to go back to glasspack style or maybe relocate the muffler further back though I doubt that will work.
« Last Edit: January 25, 2015, 02:57:50 PM by Harrison »
Callelle
Re: Time for Tons
« Reply #381 on: January 25, 2015, 03:39:17 PM »
Why couldn't you put the traction bar on the driver's side away from the exhaust all together? Don't traction bars need a shackle on the frame side?
Time for Tons
« Reply #382 on: January 25, 2015, 04:03:28 PM »
They're better on the passenger's side to counteract the torque of the motor on the chassis. Probably not a huge deal but it wasn't that hard to get it where it is. I don't need a shackle because the DOM with the joint at the frame end telescopes inside the square tube. Look at my 3rd pic.
Re: Time for Tons
« Reply #383 on: January 26, 2015, 12:32:58 AM »
that is some sweet claptrap around leaf springs! cool
Re: Time for Tons
« Reply #384 on: January 26, 2015, 10:21:45 AM »
Thanks! I think. Haha. Can't be worse than square tube driveshafts!
Re: Time for Tons
« Reply #385 on: February 25, 2015, 10:28:15 AM »
Lot of grinding... Glad its over
Re: Time for Tons
« Reply #386 on: February 25, 2015, 01:04:25 PM »
I bet... but It's not over until they hold air!
;) LOL
Re: Time for Tons
« Reply #387 on: February 25, 2015, 01:13:39 PM »
I meant grinding was over. But yeah, definitely. I TIG'd them so hopefully they work OK...
Re: Time for Tons
« Reply #388 on: February 25, 2015, 01:17:59 PM »
im confused at your grinding location
Re: Time for Tons
« Reply #389 on: February 25, 2015, 01:18:55 PM »
The plates sit inside the rim. Grind the weld off smooth when done.
