Author Topic: Time for Tons  (Read 126214 times)
Re: Time for Tons
« Reply #330 on: August 18, 2014, 12:36:33 PM »
That's awesome harry!
smike has solid inner C's so I assume their stronger than stock.
Not sure any stud would hold up against that type of impact.
Trees are unforgiving @ Speed.
Hannah
  • Full Member
Re: Time for Tons
« Reply #331 on: August 18, 2014, 01:07:59 PM »
Cool video!! Did he do everyone's?
Re: Time for Tons
« Reply #332 on: August 18, 2014, 01:11:13 PM »
Hannah... I definitely showed you that
Hannah
  • Full Member
Re: Time for Tons
« Reply #333 on: August 18, 2014, 01:12:08 PM »
Don't think so...
Re: Time for Tons
« Reply #334 on: August 18, 2014, 01:27:18 PM »
VERY cool!
Re: Time for Tons
« Reply #335 on: August 18, 2014, 01:29:58 PM »
i see a stock limited something class racer in the works!
tap and drill to coarse thread 5/8" bolts will then fail a Chevy knuckle in half rather than strip off the high steer arm.  it was worlds of upgrade from half inch stock studs.
next is what 571 and 928 have, solid knuckles.  after that, what 572 has, solid knuckles, solid C's and knewly added Artec tied in arms.  I can head on bounce a 28PSI tire off a 12" oak at 20 mph and no care.
Re: Time for Tons
« Reply #336 on: August 18, 2014, 01:32:04 PM »
Stock spindle bolts on all three cars though, right? Just high steer is stepped up.
Re: Time for Tons
« Reply #337 on: August 18, 2014, 01:34:28 PM »
solid spindle studs and locking nuts.  not sure if they are an ARP or not, but they are upgraded on all three cars.  Matts and Mine studs have a heavy tack on inside to knuckles
Re: Time for Tons
« Reply #338 on: August 18, 2014, 02:58:53 PM »
Thought I remembered seeing Smike post about 5/8 bolts. I may just replace with new quality stock and gr 8 nuts. I think the nuts are what failed... Those may have been sourced from Lowes with unknown quality
I need to look at rules and figure out what class I'd be in but I'm afraid my cage isn't going to pass inspection without an engineer signoff... Based on a convo with other friends here that are looking to get into it. I can't remember if it was wall thickness or OD or both, but I'd qualify under the 4000lb class but not the next one up.
Re: Time for Tons
« Reply #339 on: August 18, 2014, 04:12:54 PM »
Things like rcrocs racing don't have that stringent of tech like u4 does for cages.
Re: Time for Tons
« Reply #340 on: August 18, 2014, 05:12:36 PM »
def could hawg that guy in 6cyl class at Line mountain and have a blast
Re: Time for Tons
« Reply #341 on: August 18, 2014, 05:35:22 PM »
Oh that's right he is 6 cyl.
He'll yes dude!
Re: Time for Tons
« Reply #342 on: October 19, 2014, 05:28:15 PM »
Apparently ball joints are not tree-impact certified
SlvrJK
  • Full Member
