Author Topic: Time for Tons  (Read 126295 times)
Re: Time for Tons
« Reply #315 on: July 31, 2014, 09:23:43 AM »
Smike, definitely will not be in Roc anytime soon with my Jeep.
Going to do TPS, plugs, wires, cap, rotor and air filter. Go from there. Has a slight hesitation when you hit the gas and feels gutless over 2k. Also haven't done an oil change in a loooooooong time...
Re: Time for Tons
« Reply #316 on: July 31, 2014, 09:30:06 AM »
Off to a good start being  on par with the trucK
Re: Time for Tons
« Reply #317 on: July 31, 2014, 09:54:00 AM »
nono, it's gonna be WAY BETTER than the truck ;)
Re: Time for Tons
« Reply #318 on: July 31, 2014, 09:55:05 AM »
sweet back window!
Re: Time for Tons
« Reply #319 on: August 04, 2014, 09:25:38 AM »
Tune up tonight, we will see how that goes.
Other issue is ride/handing which I'm going to attribute mostly to shocks, somewhat to surely softened springs from years of crawling. When I hit whoops in the road, it feels like it almost wants to become airborne, then comes back down and I feel like I'm going to lose control.
I had a set of 8" Bilstein 5150s donated that have the body eyelet broken off. May be able to make a weld repair and get a little more out of them. Same friend has a set of good condition 12" 5150s he's willing to sell for $100.
Having been a white body shock guy my whole life, I feel these will offer a decent improvement in handing in all conditions. Is it worth springing for another couple 10" or 12" 5150s at $120/ea? Or would I be wiser to use the 12"/8" combo I'm getting dirt cheap and spring for something nicer like a 7100 or Fox emulsion or remote resi shock down the road.
Can someone (Ryan?) school me on all the different shock construction types? I'm obviously not setup to go fast, but it would be nice to not smash my bumpstops on pole line road and feel more in control on the road.
Time for Tons
« Reply #320 on: August 10, 2014, 07:55:38 PM »
Power washed, new heims installed, 5150s installed all around with rears through floor. Took much longer than I'd hoped, always a pain getting shock mounts set with bumpstop/ride height.
Drives WAY nicer now. Sweet 55mph machine
Re: Time for Tons
« Reply #321 on: August 11, 2014, 08:19:39 AM »
That looks like a nice tight hole for the shocks (nuts nudge wink wink). it really clears all the way through travel? That almost looks close enough that you could even put a rubber boot around it to seal to the floor
Re: Time for Tons
« Reply #322 on: August 11, 2014, 08:29:47 AM »
The pic doesn't show it well, but it's centered in the opening. Not much room to go either way bigger, unibody on one side and pinch seam on the other. We'll see...
Re: Time for Tons
« Reply #323 on: August 11, 2014, 05:09:13 PM »
Wax paper and great stuff!
It's all you need to keep the skeeters out!
Re: Time for Tons
« Reply #324 on: August 11, 2014, 05:20:10 PM »
needs less fluxcore  8)
Re: Time for Tons
« Reply #325 on: August 11, 2014, 10:07:59 PM »
I bet you'd be impressed what's under that layer of slag!
Re: Time for Tons
« Reply #326 on: August 18, 2014, 11:43:12 AM »
Will has been holding a series of fun races for the CT crew at some local spots. Lots of fun. But went a little too hard yesterday.
I've ended up in second the last two races we've had by less than a second each.
This race was a lot of high speed with mostly 6-12" dia rocks with minimal technical terrain. 5150s were miles better than the old white bodies! Rear end still kinda hops around but much better.
First stage of the race I was 1:21, my buddy Andy ended up with a 1:18. Second run I was trying to make up time and NAILED a tree with my passenger front tire head on doing probably 15mph or so with probably 1/2-3/4 throttle. Felt like a car accident.
Took out:
Steering box
Upper ball joint
Caliper
Appears to have exploded the nuts that hold the spindle to the knuckle
Broke welds that hold sleeve for heim bolt into knuckle
Was fun to steer the 1.5 miles out of the trail with no power assist and a broken box. Cut the pressure line to the box and looped it into the top of the res to keep the pump from running dry.
No evidence of any unibody structural damage. Lower link mount would have take the brunt of the impact and that appeared unscathed.
This things needs more tube and money thrown at the front end... or for me to stop driving it like an ultra4 car  :-\
What is the upgrade for spindle studs? Smike, did I read you drilled and tapped knuckles for 5/8 gr8 bolts?
Re: Time for Tons
« Reply #327 on: August 18, 2014, 11:52:49 AM »
That's pretty cool. Will G?
Where's the vids? :)
Whatever you do on spindle bolts, I would suggest keeping fine thread. Not sure what's been done to our cars on those. Dakota was still all stock stuff up there.
Re: Time for Tons
« Reply #328 on: August 18, 2014, 11:55:55 AM »
Yes, Will G. Just stopwatch/two way radio timing style. Casual but a ton of fun.
There's vids from the Rausch crawl daddy comp last month, but not the first race or this past weekend. He says vids are coming... Though I am afraid he sadly has higher priority video projects :)
Re: Time for Tons
« Reply #329 on: August 18, 2014, 12:10:02 PM »
