Author Topic: cj to do list...  (Read 43831 times)
Re: cj to do list...
« Reply #45 on: July 03, 2012, 12:46:55 PM »
a tank side to side but the float would get stuck if you nosed up at 50degrees or more
« Reply #46 on: July 03, 2012, 12:55:41 PM »
yeah it's motor craft or moto craft, not master craft.
« Reply #47 on: July 03, 2012, 01:29:23 PM »
I'm tired of dieseling on shutdown. Maybe I should think about a carb that's worth tweaking.
I dont think thats a carb issue...  had that on my YJ at some point in my life with the jeep
if you smell exhaust on the jeep regarless of fuel source, you have much more worse problems
i dunno, all the propane powered shit I have ever driven give me killer headaches...
its a common thing I have heard...
« Reply #48 on: July 03, 2012, 01:39:19 PM »
may just be running hot. I have no temp gauge (on anything I daily drive)
« Reply #49 on: July 03, 2012, 01:41:27 PM »
now that you say that I think it had to do with the EGR valve...
it drastically lowers the cyl head temps..
check the EGR tube and valve function
« Reply #50 on: July 03, 2012, 02:24:08 PM »
functional. I can hear them open and close under the hood.
may be a leak under the car somewhere though.
« Reply #51 on: July 04, 2012, 08:33:27 AM »
i have a cooler ill trade for a case of beer if you want, it was my old trans cooler, its in fine used shape.
my beer fridge was empty for mike this week
 ;D
« Reply #52 on: July 04, 2012, 11:06:05 AM »
carchameleon
« Reply #53 on: July 05, 2012, 01:19:08 AM »
saw that, happy with my stock ones (once i clean them up, paint & install them)
have other things to put $200 into...
carchameleon
« Reply #54 on: July 05, 2012, 02:23:39 PM »
i think i might have found a 2bb intake
and a set of not so whooped leafs
cj to do list...
« Reply #55 on: July 05, 2012, 02:25:48 PM »
Oh, duh. I have a 2bbl intake on the parts car along with the questionable Carter bbd
carchameleon
« Reply #56 on: July 05, 2012, 02:28:29 PM »
well, thats interesting, that's probably a better deal than what i found
so how much do you want for that?
smike how much do you want for that motorcraft 2bb?
cj to do list...
« Reply #57 on: July 05, 2012, 03:12:01 PM »
If you'll pull the head for me you can have the manifold(s)
« Reply #58 on: July 05, 2012, 04:18:41 PM »
 i have a Carter 1bb that was on my CJ, but the botom end Fly is bolted to a propane mixer and somewhere maybe in the old shop i have another 1bb carb, i think its an older RP mono jet that was a tank.
i do not own any 2bb carbs
carchameleon
« Reply #59 on: July 05, 2012, 04:56:51 PM »
got it
oops my bad
i'll have to look into that carb more..
