Author Topic: cj to do list...  (Read 43875 times)
Re: cj to do list...
« Reply #15 on: June 18, 2012, 03:17:31 PM »
borrow a tow dolly and drag it down with the XJ
that would kill the xj
i've still been working on it, but still don't want to drive it down
I used a XJ to tow another XJ on a dolly... works just fine
« Reply #16 on: June 18, 2012, 03:28:40 PM »
I towed a CJ on a u-haul trailer with my ZJ on 35" tires. It worked, was slow, but worked.
carchameleon
« Reply #17 on: June 18, 2012, 04:24:12 PM »
sure, what time?  i have to have time and a way to get to advance to get the right bearing...
my cherokee is not that solid...
and it has a 1" light duty hitch
« Reply #18 on: June 18, 2012, 04:36:47 PM »
zone or advance had all 4 pieces in stock you need when i checked last week for the Wonder.    i even have prices and part numbers written down at home.
carchameleon
« Reply #19 on: June 18, 2012, 04:38:40 PM »
when will you be there?
« Reply #20 on: June 18, 2012, 04:40:20 PM »
i have to shoot to wegmans when i get out around 5 so ill be back at the shop around 6
carchameleon
« Reply #21 on: July 03, 2012, 10:02:21 AM »
so i don't have a carter single barrel carb...
trying to figure out what it is...
might be a holley..
how about propane...
ha
« Reply #22 on: July 03, 2012, 10:03:21 AM »
take a picture...
« Reply #23 on: July 03, 2012, 10:10:10 AM »
motocraft?
200$ ill give you everything you need minus a tank and the hose.
mixer (i think should bolt on)
regulator
tank fitting
tank brackets brand new
i have a tank you can borrow for a little bit also
carchameleon
« Reply #24 on: July 03, 2012, 10:14:09 AM »
i have a few more pics
carchameleon
« Reply #25 on: July 03, 2012, 10:30:40 AM »
its a holley 1946 1 barrel
came on my cj stock, i wonder why i got the wrong kit..
http://www.carburetor-parts.com/Holley_1946_1_Barrel_Carburetor_Kit_p/4320.htm
that looks to be the correct kit
« Reply #26 on: July 03, 2012, 10:35:32 AM »
don’t bother rebuilding it...
If you plan on running a carb get a MC2100 conversion kit and be done...  you will thank me later..
http://www.pirate4x4.com/forum/showthread.php?t=131514
there use to be a guy on ebay who sold kits...
« Reply #27 on: July 03, 2012, 10:38:02 AM »
http://www.ebay.com/sch/i.html?_nkw=jeep+carb+2100&_sacat=0&_odkw=jeep+carb&_osacat=0
ttp://www.ebay.com/itm/MotorCraft-2100-JEEP-Carb-Upgrade-258-4-2-Non-Smog-1-08-/221058434334?pt=Motors_Car_Truck_Parts_Accessories&hash=item33781c051e&vxp=mtr
carchameleon
« Reply #28 on: July 03, 2012, 11:11:01 AM »
sounds like a interesting swap
arie, can you get that carb?  i keep seeing autozone part numbers that don't cross reference to advance
the autozone part # is 64-5174
cj to do list...
« Reply #29 on: July 03, 2012, 11:16:45 AM »
Old one is needs a rebuild I take it?
