Author Topic: cj to do list...  (Read 43827 times)
carchameleon
cj to do list...
« on: June 16, 2012, 10:30:11 PM »
here's the list i came up with tonight of stuff to do before it can be driven to rc...
-NYSI (monday)
-change transmission oil
-remount front shocks & mount rear shocks
-rear pinion bearing
-check bearings & brakes (adjust rears)
-powersteering cooler
-move grill & put fenders on (paint them?)
-tow points /bumpers?
-check diff oil /replace?
-power outlet
-yourk?
-random other small things
-put front brakes from '85 axle
probably forgot a couple of things... i'll figure it out as i go, haha
Re: cj to do list...
« Reply #1 on: June 16, 2012, 10:59:59 PM »
i have a cooler ill trade for a case of beer if you want, it was my old trans cooler, its in fine used shape.  i also have a TIny one the Erok left thats new
carchameleon
« Reply #2 on: June 16, 2012, 11:18:50 PM »
sounds good to me
cj to do list...
« Reply #3 on: June 17, 2012, 12:20:40 AM »
That gear oil pressure tank is available if you want to do duffs and trans at my place.
« Reply #4 on: June 17, 2012, 01:27:00 AM »
if it helps i found aluminum tube that is 3/4 OD and 5/8 ID. I plan to use it for my shock bushings. it was at tractor supply. you could have some if getting it from me makes sense financially. it was $5 for a 3 (?) foot stick
carchameleon
« Reply #5 on: June 17, 2012, 09:31:02 PM »
thanks
i'll let you guys know
carchameleon
« Reply #6 on: June 18, 2012, 09:58:36 AM »
off to take care of the nysi :-)
carchameleon
« Reply #7 on: June 18, 2012, 11:56:45 AM »
one thing off the list..
carchameleon
« Reply #8 on: June 18, 2012, 12:54:39 PM »
i keep adding to the list...
not looking good for the cj
bah
« Reply #9 on: June 18, 2012, 02:03:37 PM »
borrow a tow dolly and drag it down with the XJ
« Reply #10 on: June 18, 2012, 02:39:27 PM »
what happened between the hour of your last two posts that is killing your chances, your doing it wrong haha
carchameleon
« Reply #11 on: June 18, 2012, 02:50:54 PM »
that would kill the xj
i've still been working on it, but still don't want to drive it down
« Reply #12 on: June 18, 2012, 02:57:49 PM »
nothing on the lift tonight if you want a hand, i am just making some Wreck wheeling comfort tweaks to 571 tonight.
« Reply #13 on: June 18, 2012, 03:07:40 PM »
If my YJ can make it your CJ can :) Pinion bearing party tonight?
« Reply #14 on: June 18, 2012, 03:16:32 PM »
Pinion bearings fawwwwk me!!!
