Author Topic: cj to do list...  (Read 43880 times)
carchameleon
Re: cj to do list...
« Reply #30 on: July 03, 2012, 11:22:52 AM »
yes, my carb need to be rebuilt or replaced with something else
been having issues with it for a while
« Reply #31 on: July 03, 2012, 11:35:51 AM »
i have a carter, and motocraft that both ran fine on that engine  :)
carchameleon
« Reply #32 on: July 03, 2012, 11:41:42 AM »
you have this mastercraft carb?
is it for sale?
« Reply #33 on: July 03, 2012, 11:44:12 AM »
no, thats a 2bb carb, a hassel for you.
just rebuild what you have for 20$
or convert it to propane and never think about it again
carbs suck!
carchameleon
« Reply #34 on: July 03, 2012, 11:49:18 AM »
i know its a 2bb
doesn't seem to much of a pain
not having a great time finding a rebuild kit for this holley
propane isn't simple either :-p
carbs do suck
carchameleon
« Reply #35 on: July 03, 2012, 11:52:36 AM »
right, all these things i've been reading, they start with 2bb
haha...
.idiot..
« Reply #36 on: July 03, 2012, 11:55:17 AM »
propane could be running that engine in 10 minutes, it is simple.
i could have it set up by the time you ran down the street to fill the tank
« Reply #37 on: July 03, 2012, 11:56:49 AM »
you could just try it, and decide for your self it is a hassel to get fuel based on the milage you get on road.  i never really did the math, but i used about 75% of the "gallons" i used to use of Gasoline when wheeling a weekend at rausch or Gore
carchameleon
« Reply #38 on: July 03, 2012, 12:01:23 PM »
don't you have to plum cooling lines too?
ok i'm wrong, haha
i have to hook up my speedometer, haha
« Reply #39 on: July 03, 2012, 12:01:36 PM »
the Mc2100 can be fitted on a 1bbl manifold..
or upgrade to a 2 bbl manifold...
Carbs don’t suck if they are set up right... and the simpler the design the better...
propane exhaust gives me a headache...
carchameleon
« Reply #40 on: July 03, 2012, 12:25:24 PM »
either way isn't bad
i don't know
smike, is the mastercraft one you have this 2100 model?
what would you want for that?
lunchtime
« Reply #41 on: July 03, 2012, 12:31:09 PM »
go propane and at least try it.
cj to do list...
« Reply #42 on: July 03, 2012, 12:33:57 PM »
You have a MC2100 sitting, smike?
I'm tired of dieseling on shutdown. Maybe I should think about a carb that's worth tweaking.
carchameleon
« Reply #43 on: July 03, 2012, 12:43:03 PM »
i'll have to extend my exhaust so it goes out from under the cj...
it ends just above the rear axle...
should be one regardless
« Reply #44 on: July 03, 2012, 12:45:44 PM »
no, why on earth would i spend money on another POS carb    they all suck, no matter how many hours you tune them- and i would know seeing as i work with the people that designed them
i thought it was called a motor craft or something that i have
i actually went home for lunch, and i have a Carter 1bb that was on my CJ, but the botom end Fly is bolted to a propane mixer and somewhere maybe in the old shop i have another 1bb carb, i think its an older RP mono jet that was a tank.
if you smell exhaust on the jeep regarless of fuel source, you have much more worse problems
