Author Topic: 572  (Read 413259 times)
Re: 572
« Reply #1485 on: March 28, 2016, 02:15:18 PM »
gaskets and seals, along with a deep pan and filter, new range switch ordered.  141$ in parts.
Plan to swap pump and converter from spare core sitting on shop floor and run it.
Re: 572
« Reply #1486 on: March 29, 2016, 09:06:01 AM »
ordered material for new front shock mounts.  cant find any pictures or ideas near what i want to do so just going to do it haha
Re: 572
« Reply #1487 on: March 29, 2016, 03:16:24 PM »
front springs should be 250/300 on a 10" CO now.  just need to measure and adjust for my link dimension guesses.
12" 4 tube 2.5 bipass going where the old CO were.
Re: 572
« Reply #1488 on: March 31, 2016, 11:37:31 PM »
swapped in another pump to trans, added a deep pan and filter.  ready to put back in minus needing a new rear tail housing extension.
Re: 572
« Reply #1489 on: April 02, 2016, 01:17:56 PM »
back in car and hooked up.  turns both ways now.  should be ready for a lot test after seat and zip ties.
Re: 572
« Reply #1490 on: April 02, 2016, 07:07:19 PM »
back in business.  full tear around shop all is well.  snowing now :(
swapped out broken power steering cooler.  also found a finger size rock that had one of my trans cooler fans locked solid, fixed.
race ready minus some fluids checks, and waiting for shocks.
Material for front link saddle mounts came in.  shouldn't be more than a night of fab to get new shocks on when they show up.
Re: 572
« Reply #1491 on: April 18, 2016, 04:34:53 PM »
Fedex from OH should get me a front cover by wednesday or so.  Probably should prep it and pull the cover to make sure anything else isnt broken ha
race prep / VA prep will in volve grease job and bolt check, tool pack for wreck wheeling.
Re: 572
« Reply #1492 on: April 21, 2016, 02:24:22 AM »
new front diff cover, grease job, bolt check, fueled and loaded in the trailer for 3 days of wheeling and a 50 mile race.
Re: 572
« Reply #1493 on: May 03, 2016, 11:32:14 PM »
solid run on this unit.
prerunning i hit something the hardest i ever have that threw the front diff 3' in the air at 30mph.  worse than the stump hit that failed the 3 link.  kept on it, found another dented diff cover when returned to pit.
no race issues, treated the car like a stole it entire course, almost ran out of talent on the back straight near 81 but stayed in it and powered out of loosing the rear end down the ravine.  Trans performed as it should with new pump install.  power of car more than adequate.  looked up and saw 67 in the woods straight the instant before letting up far beyond point of fear.
3 link feels loose, would like better brakes and front shock package is still a mess at low speed chop. seems to be best at 40mph over 6-10" chop but that takes commitment.
Re: 572
« Reply #1494 on: June 02, 2016, 09:30:07 AM »
bolt check and loaded
fox has new shocks done
Re: 572
« Reply #1495 on: June 02, 2016, 09:41:20 AM »
7 weeks? 8?
Glad they’re finally done. Oi!
Re: 572
« Reply #1496 on: June 02, 2016, 01:05:57 PM »
the quote has 3/14 on it
ha, i didnt really push it.  chris doesnt work with Wayne anymore either.
Re: 572
« Reply #1497 on: June 04, 2016, 09:47:28 PM »
carrier bearing failure, loop support contained rear shaft and any other damage- did its job.  probably could have continued but it sounded like rear gear set.
front right flat- looks like driving on it carefully at a slower pace saved the wheel.
Re: 572
« Reply #1498 on: June 06, 2016, 08:47:30 PM »
considering changing to a 3" pillow block bearing.  need to wash and tear down tomorrow night.  bah.
Re: 572
« Reply #1499 on: June 10, 2016, 01:50:38 AM »
rebuild rear shaft tonight and installed.
discovered the grease fitting is not to grease the alignment, but there is a grove and hole in the actual bearing that pumps grease into the internals of the pillow bearing.....
fail on my part.
cant believe all of our cars have lasted so long with out a few shots of lube there ever.
