Author Topic: 572  (Read 362092 times)
Re: 572
« Reply #1515 on: July 01, 2016, 10:19:55 PM »
upper CO mount thats happy still hasnt appeared.  all other work sorted and just about done with loose bolts.
Re: 572
« Reply #1516 on: July 03, 2016, 11:34:08 PM »
good day at rausch.  front shocks feel great- still room for a lot of tuning but definitely get things moving around more and under control.
Re: 572
« Reply #1517 on: July 11, 2016, 10:04:54 PM »
race prep list:
wash
check front end out, replace a left spindle bearing if needed
replace / free one of the trans fans thats locked up
fluids
fuel
eval spare tire situation.
Re: 572
« Reply #1518 on: July 13, 2016, 12:33:15 AM »
race prep completed tonight thus far:
car washed
front axle wheel bearings and king pins tightened up
snapped right king pin adjuster, need to source a fine thread 3/4" bolt to fix
seized trans cooler fan replaced
found main radiator fan to be loose and flopping, close to failure.  replaced.
lube u joints
front bipass upper bolts changed for new
check coolant level
fuel
air pressures
source missing radio thumb screw
Re: 572
« Reply #1519 on: July 13, 2016, 08:39:31 AM »
*bypass
Re: 572
« Reply #1521 on: July 13, 2016, 10:27:03 AM »
2.5 is plenty long.
staying with the allen set screw style is much easier for adjustment, what I have to do with 2 same size hexes above each other is kinda annoying.
Re: 572
« Reply #1522 on: July 13, 2016, 11:57:54 AM »
well if it works out ill have a 5 pack to pick up Friday lunch time at granger and you can have 2 of them
Re: 572
« Reply #1523 on: July 13, 2016, 01:37:27 PM »
side note, changes to my radiator shroud last go around with bolted in tabs and weld nuts, made changing a radiator fan a 20 minute job instead of a 5 hour job.
winning.
Re: 572
« Reply #1524 on: July 15, 2016, 08:51:13 AM »
email this morning says granger has my 3/4" set screws ready for pickup.  grab at lunch, install at line Mt.  i welded a nut onto what snapped off, but left it so its mobile.
Re: 572
« Reply #1525 on: July 15, 2016, 12:44:55 PM »
king pin adjusters in hand
my lord the 20'syr old parts girls behind the Granger counter-  i gota will call more stuff there
Re: 572
« Reply #1526 on: July 18, 2016, 04:57:52 PM »
king pin adjuster swapped no issues at line mt friday night.  2.5" is probably .5" longer than original, no big deal.
shock notes-  much more compliant on little chop for a much better ride over all.  still harsh on mid to high range / high speed impacts.  Coil over gets warmer than bipass.
Re: 572
« Reply #1527 on: July 21, 2016, 07:59:27 AM »
washed
needs an air clearner service.  way down on power responce.
RCV's are really getting BAD
Re: 572
« Reply #1528 on: August 16, 2016, 11:52:25 AM »
car hasnt been serviced since KOH really
14 bolt tear down and spindle replacement
full heims check / replace
front end RCV issues
start looking at a 14 bolt 40 spline build
Re: 572
« Reply #1529 on: August 19, 2016, 11:25:28 AM »
looking like 14bolt spindle replacement not as easy as i had imagined.  looks like guys are slugging on at  the tube.  that sounds silly.
