Author Topic: 572  (Read 413425 times)
Re: 572
« Reply #1455 on: January 12, 2016, 11:00:49 PM »
new wrap and tins installed tonight.
just need to charge shocks and bumps closer to load night, new lug nuts, and strap down the tool bags.  ready for the lake bed.
Re: 572
« Reply #1456 on: February 10, 2016, 03:38:57 PM »
koh2016 notes
shocks still suck
shattered power steering cooler
trans failure (snap, not slippage)
Re: 572
« Reply #1457 on: February 10, 2016, 03:41:54 PM »
1. reman trans
2. 12 or 14" 2.5" bipass fronts with 10 or 12" coil carriers
3. 14 bolt front axle
4. turbo 5.3 build / dyno work
5. investigate brakes and steering upgrades
Re: 572
« Reply #1458 on: February 11, 2016, 12:16:57 PM »
Oh this could get interesting
Re: 572
« Reply #1459 on: February 14, 2016, 07:37:38 PM »
going to concentrate on getting this thing sorted this year to either sell or hit back racing hard again in 2017.  By this winter, i may start on a new 2 seater multi use truck.
Racing is getting tiring, id really like something with summer plates on it that can take my abuse
Re: 572
« Reply #1460 on: February 15, 2016, 12:42:30 AM »
If your going to sell 572, just repair the the tranny, let the new owner sort out the rest.
I agree that a dual purpose rig would be nice.  But the fact is you crossed over to dedicated off road vehicles. Thats hard to come back from.  No way could i tolerate 100:1 gear ratios and slow wheeling.   Thats the only way those dual purpose rigs survive.
Re: 572
« Reply #1461 on: February 15, 2016, 08:18:28 AM »
I've not experienced the full race car stage but I can see Gif's logic.
But sMike didn't say anything about going slow, just being able to plate and drive what he races.  4600 class calling?
I can't wait to see what sMike comes up with next!  I've thought something might be changing soon...  :P
Re: 572
« Reply #1462 on: February 15, 2016, 08:47:56 AM »
mild pro4, that runs the street and crawls 95% of what the buggies do would be the theme haha
who knows havent really though much about it yet.
Re: 572
« Reply #1463 on: February 15, 2016, 09:20:48 AM »
I got a 68 commando that's worth more in parts to me than a complete vehicle..
clean NYS title..
Re: 572
« Reply #1464 on: February 15, 2016, 12:17:08 PM »
Wonder how hard it would be to have something like this be street legal
Or
Re: 572
« Reply #1465 on: February 20, 2016, 05:05:39 PM »
unit relocated to the shop.
90% unpacked from KOH
Re: 572
« Reply #1466 on: February 21, 2016, 06:45:17 PM »
got a 1/3 into trans pull and found the range shifter position sensor is cracked.....
stopped and need to do research.  probably should have read trans codes, and possibly change this sensor or at least swap with the other one sitting on the shop floor.  gona be pissed if thats all it is.
Re: 572
« Reply #1467 on: February 21, 2016, 08:25:27 PM »
range shifter position? Is that something that reads shifter position in addition to where the control valve is in the valve body?
Re: 572
« Reply #1468 on: February 21, 2016, 08:53:40 PM »
not a ton of info i can find (maybe my issue)  i thought the mechanical lever only really actuates the park pin and detents for the other possitions.  the sensor is what tells the trans what to do.
other tell tail i found with my no motion in any gear, check level engine off, then check level engine on in P, if same level, pump blown.  if lower, pump is working.
Re: 572
« Reply #1469 on: February 21, 2016, 09:04:36 PM »
Are you certain the pump runs in Park? I don't know for certain on the GM trannies, but I do know on the Mopars you must check in N. The pump is disengaged in P. Best practice to cool them off in N for the same reason.
