Author Topic: M4wdriveway Yota Exo  (Read 139984 times)
« Reply #90 on: March 21, 2012, 10:01:45 AM »
Because you never get things perfectly in plane, and end up killing bushings and bolts and mounts like 571 does.
Don't worry, smike will say for your use it's fine...
Re: M4wdriveway Yota Exo
« Reply #91 on: March 21, 2012, 10:08:36 AM »
lol
« Reply #92 on: March 21, 2012, 10:24:19 AM »
toyota use is a little different... i never had issues or cared about 1/8 slop on the CJ.
erik does the same with his buggy with a little better setup with Bronze bushings that are replaceable.   Tractor supply off the shelf components were the attraction for me.
« Reply #93 on: March 21, 2012, 10:42:51 AM »
I'm running TRE's so is that the better way to go?
« Reply #94 on: March 21, 2012, 11:05:47 AM »
id go 3/4 or 7/8ths heims honestly.  i hate TRE, but they seem to work well on the Dak.
« Reply #95 on: March 21, 2012, 11:31:03 AM »
they seem to have proven themselves a weak point on the Dak... have had VERY few steering issues over the years that weren't a TRE bending like a pretzel
« Reply #96 on: March 21, 2012, 11:42:02 AM »
and the list continues lol
Would those included in your old tie rod smike? ;D  I can probably re-coop a couple hundred for my high steer
« Reply #97 on: March 21, 2012, 12:07:26 PM »
actually i am upsizing on my new tie rod, so the old 3/4 heims are available.  i wont have a need for the spare or two that i have also.
they are so cheap from ruff stuff though...
« Reply #98 on: March 24, 2012, 09:56:16 PM »
My HF master disconnect has shit the bed after 2 weeks lol
« Reply #99 on: March 24, 2012, 10:06:36 PM »
Quality.
« Reply #100 on: March 24, 2012, 10:15:21 PM »
I have a tie rod with the bungs welded in from Atom, I replaced it with a longer one. Its 1.5" .250 wall square. I even have extra bungs if you need to shorten it.  If you want it let me know.
« Reply #101 on: March 26, 2012, 08:24:31 AM »
cool, I'll grab it and see which option fits best
« Reply #102 on: March 26, 2012, 12:22:05 PM »
finally sent hydro assist back.  new cylinder ordered.  purchased new water pump and disconnect switch ::) from the Eagle.  harnesses should be here tomorrow.
« Reply #103 on: March 29, 2012, 08:07:35 AM »
I dont think the S-10 rad is going to work, too wide.  Be nice to mount it in the back, but thats a whole nother project to do before big hawgs  ::)
« Reply #104 on: March 29, 2012, 08:30:37 AM »
My belts came with wrap around ends, I ordered bolt in, awaiting a response  >:(
