Author Topic: M4wdriveway Yota Exo  (Read 139760 times)
Re: M4wdriveway Yota Exo
« Reply #60 on: March 16, 2012, 02:03:40 PM »
awww man, I just noticed these bastards dont send the $3 fittings you need to tap the steering box with the hydro assist kit  >:(
is there anywhere local to get a 1/4" pipe to #6 JIC fitting?
« Reply #61 on: March 16, 2012, 02:08:41 PM »
TSC should have them.
« Reply #63 on: March 16, 2012, 03:38:21 PM »
Brass
« Reply #64 on: March 16, 2012, 04:34:42 PM »
i think i have you covered,  #6 is 3/8?   or 6/16"s?
« Reply #65 on: March 16, 2012, 09:33:36 PM »
Either
« Reply #66 on: March 19, 2012, 10:10:29 AM »
You got any e-fans laying around smike?  Mine stocker is hosed, you can wiggle it like 2 inches lol.
I think may have fucked up on my hydro assist ram, I pulled the trigger on the 2"x6" ram on the last day of A 25% off sale, but after doing some research the 1.5"x6" is designed for the stock pump and the 2" is for the upgraded pump.  So I either exchange it at $30 shipping each way or order the upgraded pump for $150 or give it a whirl and order it later if it blows and do the work twice  ::)
« Reply #67 on: March 19, 2012, 11:05:07 AM »
should have just bought my full hydro setup when i got full PSC  :)
i would think a 2" would just be slower and easier on the pump / box
« Reply #68 on: March 19, 2012, 11:08:19 AM »
since it's assist it should kinda match the box and ram, they might fight each other.  I bet there's a restricted oriface somewhere that you can drill out for more flow.
« Reply #69 on: March 19, 2012, 11:15:53 AM »
i have a couple fans i believe.
« Reply #70 on: March 19, 2012, 11:22:13 AM »
I've asked you numerous  times when is this going down! :P
« Reply #71 on: March 19, 2012, 12:00:25 PM »
2500$ you can every thing between the link bolts and the wheel studs :)
« Reply #72 on: March 19, 2012, 12:07:48 PM »
I want a ram and an orbital and some hoses
« Reply #73 on: March 19, 2012, 12:14:06 PM »
these are all things that can be purchased off the shelf
« Reply #74 on: March 19, 2012, 12:21:51 PM »
I got $200 into the assist.  I figured minimum $500 for full hydro
