Author Topic: M4wdriveway Yota Exo  (Read 139933 times)
Re: M4wdriveway Yota Exo
« Reply #105 on: April 02, 2012, 08:12:57 AM »
belt hardware on the way from poly performance, installed other than that.
cylinder should be here today.
assist should be arriving in fresno toady and orbital should then be on its way, cross your fingers for firday delivery.
changed the water pump Saturday, broke almost every bolt getting to it, and had to sawzall off the fan clutch.  the studs that came with it were not threaded enough to install the pulley with out the fan clutch so that halted that project.  The s-10 rad i grabbed from smike is too wide and completely opposite hook ups so that's out, probably just going to buy a stock rad.
« Reply #106 on: April 04, 2012, 10:13:43 AM »
Where can I get a 50a relay for this e-fan?  all i can find is 20 or 30a at the parts stores
Great advance story yesterday, I overhear lady ask for a muffler clamp for a Camry, guy says oh looks like we dont carry those for that car  ::)
« Reply #107 on: April 04, 2012, 12:15:18 PM »
doubt you need a 50amp relay
how is 571 set up? two 40amps for the rear and one for the front?
« Reply #108 on: April 04, 2012, 12:32:30 PM »
nu way... duh?
available in SMP or cole Hersee
« Reply #109 on: April 04, 2012, 12:33:09 PM »
something like that.  if you can't find a big enough relay just run two in parallel.
« Reply #110 on: April 04, 2012, 01:13:57 PM »
That fan has some massive wire on it, i was just guessing 50.
I looked at nu-way yesterday and did not see any 30a+ relays
« Reply #111 on: April 04, 2012, 01:29:51 PM »
ask...  we are not retail oriented...
we have the ability to order ANYTHING under the sun..
its just a matter of how long and how much...
Farmington/Carter are the best in terms of the guys sitting and looking through books with you..
« Reply #112 on: April 04, 2012, 01:40:05 PM »
will do.
« Reply #113 on: April 04, 2012, 01:54:04 PM »
and you can always drop the "arie said you will help find this" line..
Advantage ER is good too when their not swamped answering phones...
« Reply #114 on: April 04, 2012, 01:57:10 PM »
haha.  I usually swing by carter on the way to RGH.
« Reply #115 on: April 04, 2012, 04:07:38 PM »
Farmington is awesome. They help me with anything I need, and know what they are doing. Robin is a great lady, and always says good things about Arie.
« Reply #116 on: April 04, 2012, 06:13:06 PM »
Robyn even let's me walk around the back room trying to match up crazy brake rotors. Try that at Autozone.
« Reply #117 on: April 04, 2012, 06:14:11 PM »
They let me do that too. It's great.
« Reply #118 on: April 04, 2012, 11:53:31 PM »
Done it at a random unknown Advance in bumfuck NY with Wingman and F700 parts! :)
When you walk in dirty and desperate things are different... Haha
« Reply #119 on: April 05, 2012, 07:37:57 AM »
Ahh, good times... :-\
