Author Topic: M4wdriveway Yota Exo  (Read 139936 times)
Re: M4wdriveway Yota Exo
« Reply #225 on: June 20, 2012, 08:53:24 AM »
Any cheap filter I see is "Not For Fuel Injection".  What are you running?
« Reply #226 on: June 20, 2012, 08:56:29 AM »
Coarse prefilter, fine after filter.
« Reply #227 on: June 20, 2012, 09:15:31 AM »
most cheap anything filters are 5-15um put one before the pump.  The pump is what you need to worry about the the injectors.  the injectors have there own 30um filters and wont care.  if your pump is graveling enough to clog the injectors you have failed already
« Reply #228 on: June 27, 2012, 07:40:23 AM »
new trailer ubolts
« Reply #229 on: June 27, 2012, 07:41:07 AM »
axle bendage, see gap at bottom of drop
« Reply #230 on: June 27, 2012, 07:53:54 AM »
we could probably fix that axle with the pipe bender and my digital level on the lift.....
« Reply #231 on: June 27, 2012, 08:34:41 AM »
I couldn't think of a way to get 3 points on it to bend it in the correct location, but I'm sure we can figure something out
« Reply #232 on: June 27, 2012, 08:53:17 AM »
why dont you drop your trailer off so i can use it to scrap this week, and ill bend your axle back.  its just the one axle right?  so i could match it up to the good one.
« Reply #233 on: June 27, 2012, 09:46:30 AM »
Is that really something like a quarter inch difference?
With movement there it wouldn't be bent tube it would be bent drop or spindle wouldn't it?
« Reply #234 on: June 27, 2012, 09:51:22 AM »
ya bend drop bend thingy, doesnt matter.  doubt the spindle is bent, it would be chewing bearings, spitting grease ect.
put the pipe bender in the center of the axe and bend the middle up
« Reply #235 on: June 27, 2012, 10:19:26 AM »
but that is going to effect both sides, this pict looks like it is the drop that is bent
« Reply #236 on: June 27, 2012, 10:37:48 AM »
unless its fixed it self since last year, both front axle tires were tipped way out at the road.
« Reply #237 on: June 27, 2012, 02:57:04 PM »
Just the one sides bent
The rear axle looks like the drop was cut off and welded back on, its about an inch narrower than the front too
« Reply #238 on: June 27, 2012, 02:59:32 PM »
I need it to help somebody move saturday ::).  I can swing it by sunday or next week.
« Reply #239 on: June 27, 2012, 03:41:41 PM »
if only one side is bent i cant help you
get rid of that pile
