Author Topic: M4wdriveway Yota Exo  (Read 139936 times)
Re: M4wdriveway Yota Exo
« Reply #255 on: July 23, 2012, 10:36:33 AM »
its stock, but it doesn't come close to running out of fluid either way, plus a huge cooler.  I'm thinking its worth a try, there was one a JJ i should go get.
« Reply #256 on: August 20, 2012, 09:59:23 AM »
Found this monster PS res off of a landrover.  Drilled out the pump restrictor, figured if it doesn't get better its time for a different pump anyhoo.
Been reading up on pumps, a lot of yota guys swap to a chevy 'P' pump or the Saginaw 'TC'.  Both of which are pretty rare in remote res and serpentine.  Probably not really worth messing with when the TG 1650psi pump is bolt on for under $200...
Installed a sweet spare parts storage box, everything but a front axle housing in there ;D
« Reply #257 on: August 20, 2012, 10:47:06 AM »
Getting her ready for Jareds?
« Reply #258 on: August 20, 2012, 10:50:54 AM »
oh shes ready!   I give the PS pump 20 minutes ;D
« Reply #259 on: August 20, 2012, 11:22:53 AM »
i probably have 3 or 4 Ppumps laying around that are fine, in serp or vbelt....as for remote, that takes two clamps and a piece of radiator hose....
a Van LS pump is also remote FYI,
Any TBI chevy motor will be serp, probably the vans would be remote.
« Reply #260 on: August 20, 2012, 11:27:53 AM »
when is jareds?
« Reply #261 on: August 20, 2012, 11:50:26 AM »
when is jareds?
This coming Saturday, 8/25. 2pm start I do believe.
« Reply #262 on: August 20, 2012, 11:56:19 AM »
I dont believe your invited  ;D
I looked at the astros at JJ, they were remote res but had 3 ports pumps, looked like vaccume assist or something?  What are you chevy guys running the P pump with attached res?
« Reply #263 on: August 20, 2012, 12:05:34 PM »
Mine has 3 hoses, pressure return and return for the hydroboost brakes. I just capped the third one.
« Reply #264 on: August 20, 2012, 12:06:32 PM »
Ahhhh
« Reply #265 on: August 20, 2012, 12:45:57 PM »
ya same on a lot of pumps with a third return, just cap them.
« Reply #266 on: August 21, 2012, 09:52:44 PM »
Bled it out good, she sounds much better
« Reply #267 on: August 24, 2012, 07:59:14 PM »
This one runs better
« Reply #268 on: August 24, 2012, 09:52:26 PM »
Looks like its got better tires too
« Reply #269 on: August 24, 2012, 10:06:01 PM »
Nick and the ZJ should come
he is grandfathered in be cause he is such a purple panzy
