Author Topic: ( to be determined)  (Read 44578 times)
Re: ( to be determined)
« Reply #45 on: March 24, 2020, 09:43:00 AM »
I have sanitizer and toilet paper!
« Reply #46 on: March 24, 2020, 10:22:50 AM »
So it's popped before and the edges of the teeth on the dogs are rounded off. If you're lucky maybe you can tear the winch apart and turn them 180Ëš to use fresh material?
« Reply #47 on: March 24, 2020, 11:11:00 AM »
4 seater family machine? i dont know id probably just splurge for a new 250$ winch.  i remember when matt wound his rope backwards and a screaming woman squealing down the back side of double bump occurred as the winch unwound with no brake haha
« Reply #48 on: April 02, 2020, 04:12:13 PM »
Put winch from tj on this thing and traded steel cable for the rope from bad winch. Will find a steel pin to make a removable free spool locm and use old unit and mount to trailer.
« Reply #49 on: April 08, 2020, 04:36:30 PM »
Got the rear bumps done.
SB406
  • Newbie
« Reply #51 on: April 27, 2020, 08:32:22 AM »
I love that the square driveshaft still has the hole in it for a receiver.
I rocked the squares for years. I believe my old buggy is still running them.
« Reply #52 on: April 27, 2020, 08:49:21 AM »
Yeah I have to source some 1310 yokes so I can make a spare to have on the trailer.
wnyjpgy
« Reply #53 on: April 27, 2020, 09:44:49 AM »
Tom, If you don't find any 1310 stuff around let me know what you need, cv/non cv/whatever. I have a pile of that stuff upstairs in my shop..
« Reply #54 on: April 27, 2020, 09:50:29 AM »
i think the drive shaft from the 54 chevy i cut up has 4 of them in good shape also.  they might be 1350 though
« Reply #55 on: April 27, 2020, 11:41:22 AM »
I'm going strikeout my last statement about needing 1310 Yoke's until I measure because I just read where I originally posted it needed 1410 on transfer case output.
« Reply #56 on: April 27, 2020, 12:44:43 PM »
Pretty sure I still have square driveshafts around smile gave me years ago, don't remember what size yokes where on them
« Reply #57 on: April 27, 2020, 03:46:09 PM »
if i gave you shafts they would have been from my CJ that was 75% 1310 and maybe 1350 at the rear axle.   if i gave you parts to build they were probably all 1350 junk.
« Reply #58 on: May 06, 2020, 11:45:47 AM »
Started to shape the aluminum sheet to be a roof. Need to trim and add more tabs.
« Reply #59 on: May 06, 2020, 11:46:43 AM »
Drive shaft is 1410 yokes. So need to find what those are from.
