Author Topic: ( to be determined)  (Read 44506 times)
Re: ( to be determined)
« Reply #30 on: March 01, 2020, 10:53:33 AM »
Looking a little different
« Reply #31 on: March 04, 2020, 09:55:51 PM »
Cage updates
« Reply #32 on: March 04, 2020, 09:57:01 PM »
Found new friend to help look into hard to see areas!
« Reply #33 on: March 05, 2020, 11:25:06 PM »
rear shocks re mounted.
« Reply #34 on: March 06, 2020, 05:15:46 AM »
Hey they are even now.
« Reply #36 on: March 06, 2020, 08:25:58 AM »
i asked matt if he has any short ones left from the front of his buggy before we changed it up.  he is checking
« Reply #37 on: March 06, 2020, 08:27:53 AM »
I texted him too
« Reply #38 on: March 06, 2020, 09:04:37 PM »
Locked?
« Reply #39 on: March 10, 2020, 09:18:58 PM »
Found this website https://www.aa-mfg.com/product-category/tabs/
for tabs and such. Just bought trick tabs for mounting my roof for
 $.68 a piece  plus a flat rate ship box.
« Reply #40 on: March 11, 2020, 12:16:36 PM »
Sign up for their email they have free shipping deals and 20 off coupons.  I have bought everything from disk brake mounts, tabs, cleco's, etc
« Reply #41 on: March 19, 2020, 04:12:29 PM »
Picked this back up from M4WD on Wednesday. After sitting in the garage over night , this afternoon I went to start on my roof template and saw the buggy leaning hard to the right. The rear right Air shock is now fully stuffed. With no nitrogen left in it. Mike I know you mentioned it leaked. Do you think it just needs a new shrader valve? And will any do or do I need to call ADS about it?
« Reply #42 on: March 19, 2020, 05:01:36 PM »
a normal sharder from a high pressure valve stem should be fine
« Reply #43 on: March 24, 2020, 08:51:09 AM »
Worked on the winch(smittybilt xrc8)this past weekend. Replaced the clutch lever hoping it would fix the issue of it unlocking under load. While it has a more positive feel with a good detent it still fails. There is a pin that holds the lever in the cover if removed I can over rotate past the detent and it locks and engages under load. With out the pin the lever will pull out. When I placed a call to smittybilt they informed me that the winch is discontinued and no longer able to get parts.
This thing definitely lives up to is acronym
« Reply #44 on: March 24, 2020, 09:42:16 AM »
Sell a kid?  Or a kid-ney?  :P
