Author Topic: ( to be determined)  (Read 44505 times)
( to be determined)
« on: November 30, 2019, 02:10:42 AM »
Buggly( ugly buggie) / CocaCola Buggie
So I went for a drive to the west and this followed me home.
Specs:
93 Cherokee Tube wonder 4seats
2003 5.3 Chevy with 4l60
2006 super duty d60 front axle 5.29 gears welded be diff with lockout hubs
10.5rear axle 5.29 gears limited slip
D300 twin stick big bearing upgraded and shaft
Full hydro double ended ram with psc orbital,pump,and resivor
42" super swamper bias /39.5 BFG REDS
Recentered h1 rim with headlock and inserts
Dirty Life beadlocks
Sent from my SM-G975U using Tapatalk
« Last Edit: April 07, 2025, 08:39:53 AM by dubt »
Re: ( to be determined)
« Reply #1 on: November 30, 2019, 06:34:32 PM »
Nice!
« Reply #2 on: December 01, 2019, 08:47:03 AM »
Get that rear welded up. I don’t understand leaving a rear limited on a trail toy.
I guess I did it briefly myself too but I really don’t get even where I was coming from when I did it myself. I guess fear of turning radius impact? Not worth it!
« Reply #3 on: December 01, 2019, 05:06:12 PM »
let me know if you want to bring it over sometime and put it on the lift and give it a once over sanity check before next season.  looks cool for a turn key fun machine!
« Reply #4 on: December 01, 2019, 05:18:50 PM »
That would be great. Thanks
« Reply #5 on: December 01, 2019, 05:21:14 PM »
After some creative suck downing of the suspension. Got it to just squeeze into the garage.
« Reply #6 on: December 01, 2019, 05:22:02 PM »
Did a quick rip around my yard with the kids.
« Reply #7 on: December 01, 2019, 05:38:35 PM »
Is that steering ram single sheer?
« Reply #8 on: December 01, 2019, 05:53:39 PM »
Sure is, that’s sketch.
« Reply #9 on: December 01, 2019, 06:35:20 PM »
Yeah may need a new ram in the future
« Reply #10 on: December 01, 2019, 09:48:56 PM »
Should be able to swap ends, as long as they’ll loosen.
« Reply #11 on: December 01, 2019, 10:09:56 PM »
Or convert tie rods to clevis end
« Reply #12 on: December 02, 2019, 09:04:48 AM »
looks like the eyes on the ram are fixed, no spherical bearing. so no clevis end tie rod without changing ram end anyway.
« Reply #13 on: December 02, 2019, 12:01:27 PM »
Ram end
« Reply #14 on: December 02, 2019, 12:30:03 PM »
why tighten all the way when you can have a split ring lock washer keep a bit of preload, anyway?
