Author Topic: 1946 International KS-5  (Read 47256 times)
Re: 1946 International KS-5
« Reply #60 on: January 03, 2019, 06:16:50 PM »
I think we have success!  hooked up can hi and low from the trans to the ECM and gave the wake up ignition power.  plugged back in trans harness and still have forward and reverse which is much better than the last time the trans was plugged in!
noting here, if its funny OD issues, there is a brake switch input to TCM to release the lockup i assume.  should be an easy hookup if needed later.
made a floor support, bolted floor tins back in, bolted lower steering column down,  mounted gas petal, affixed a brake switch and wired it it.
major progress!  would be driving it tomorrow if the salt was gone!
hit list
cab marker lights in the mail
head liner install
rubber floor mat install
new wiper motors and switch in the mail, install
mount seat and raise it 2"
« Reply #61 on: January 05, 2019, 11:24:41 PM »
cab clearance lights installed and wired
electric wipers installed, adjusted, wired
picked up a 3'x4' rubber mat from TSC to trim down for the floor
« Reply #62 on: January 06, 2019, 09:13:36 PM »
put the floor in tonight after getting home from buffalo visit.
best 20$ spent on the project.  Im getting too good at this.....
« Reply #63 on: January 06, 2019, 10:30:42 PM »
The horse mat right?
Been meaning to pick some up and try this in the rover..
« Reply #64 on: January 06, 2019, 10:58:36 PM »
ya from TSC.  they have two kinds.  a 4'x6' sheet that has ribbed texture and its legit 3/4" thick   (heavy!) 40$
this time i went with the smaller 3' x 4' one that is a little thinner like 5/8" and has a different texture surface. 20$  worked out great.
« Reply #65 on: January 08, 2019, 06:42:56 PM »
insured today.  35$ a year to add, ha.     plates from 49 should be back in mail to me tomorrow.
« Reply #66 on: January 13, 2019, 02:17:54 PM »
good test drive.  motor and trans lots of power no issues.
has a little power steering whine need to check that, and the driver mirror mount needs a support inside the door to stop the rattle.
other wise sweet machine.  need to hit the dmv this week.
have a buyer, will see if he comes though.
« Reply #67 on: January 13, 2019, 08:41:28 PM »
dirty night run down to the CAT scales this unit is 6440lbs!
« Reply #68 on: January 13, 2019, 09:01:04 PM »
 9 forms for this guy filled out.  DMV tomorrow or tuesday!
manny attempts cant get a good VIN etch.  bringing the VIN tag in my pocket and have super good pictures printed out.   Hopefully the dumb bitch wont require a sheriff verification again.
« Reply #69 on: January 13, 2019, 09:24:04 PM »
will be a last ditch effort if needed, and will not leave my hands.  its legit held on by 4 flat head screws on all 4 of my trucks i have done.....
« Reply #70 on: January 14, 2019, 06:31:00 PM »
scrapped out dust and paint with a needle and got a semi decent vin Etch.  should be good to go.
never transferred Historical plates before, doesn't seem to be clear if MV82 is good enough. MV440H doesnt have a transfer section.... love the DMV rolling the dice.  folder up to 11 documents this time!
« Reply #71 on: January 14, 2019, 08:20:52 PM »
listed for sale 12K.... 9500 is bottom drive home
« Reply #72 on: January 14, 2019, 08:21:29 PM »
for sale 2
« Reply #73 on: January 14, 2019, 08:22:11 PM »
f0r sale 3
« Reply #74 on: January 14, 2019, 08:23:15 PM »
for sale 4
