Author Topic: 1946 International KS-5  (Read 47244 times)
Re: 1946 International KS-5
« Reply #45 on: December 15, 2018, 03:19:30 PM »
Those old split rims sure are hazardous!
« Reply #46 on: December 23, 2018, 02:06:15 PM »
trimmed headake rack bolts today.
looked at tail lights.  ambition low!
« Reply #47 on: December 28, 2018, 05:54:55 PM »
put a solid day of wiring in on this guy.  getting closer.  rear lights and trailer plug hung. still a few more hours but getting there.
« Reply #48 on: December 29, 2018, 09:53:07 PM »
99% wired minus needing a brake switch (curse 2014 GM again), wipers and maybe some cab lights later.
hood latch work completed and functional.
crank out windshield mechanism repaired and functional.
hit list:
trans canbus wires need to be fixed
floor pans need re installed
steering column lower mount fixed to floor
seat permanently mounted
mirrors need installed
needs wipers.
needs a brake switch fitted.
« Reply #49 on: December 30, 2018, 01:57:06 PM »
looks like you really have the wiring harness down.  looks clean.
« Reply #50 on: December 30, 2018, 06:22:12 PM »
transmission shifter completed, fresh west coast mirrors mounted, mud flaps installed to bed today.
« Reply #51 on: January 01, 2019, 05:48:43 PM »
side steps mounted, filler neck mounted.
looks like a real truck now!
« Reply #52 on: January 01, 2019, 06:53:35 PM »
havent been able to find <edit: was being lazy, see below> schematics or info i need to tackle getting the 6l90e to talk to what it needs.
900$ fix here.  bah
https://www.lsxceleration.com/pcs-gm-6l80e-6l90e-transmission-control-module-tcm-2650/
« Last Edit: January 01, 2019, 07:37:09 PM by M4wdFab »
« Reply #53 on: January 01, 2019, 06:59:32 PM »
John C know anything?
« Reply #54 on: January 01, 2019, 07:01:19 PM »
« Reply #55 on: January 01, 2019, 07:26:22 PM »
i did get some feed back from brendan to try.
Quote
The ecm and tcm in both must communicate with each other. Sometimes data circuits go through other modules between the two. Unplug one module the entire chain is broken and no communication. There is also a accessory wake up signal (dark blue wire) that may need hooked up.it's a 12v+ signal that the bcm usually provides in the stock vehicle to enable communications.
Quote
In the end, you want the ECM data wires to go to the TCM, than the TCM to the OBD2 port. (TCM Inside 6l90 trans)  So ECM pins 27,28 will go to Transmission pins 11,10.  Next, Transmission pins 13,14 go to the OBD2 port.
« Reply #56 on: January 01, 2019, 07:33:00 PM »
pin9 BU blue?
« Reply #57 on: January 01, 2019, 07:35:05 PM »
PCM, 73 pin BLACK connector for 27,28 location:
« Reply #58 on: January 01, 2019, 07:36:27 PM »
enough i think above now to run 3 wires from trans connector to PCM connector and see if we are good!
« Reply #59 on: January 01, 2019, 07:50:01 PM »
