Author Topic: project: 1949 FlatShopRat  (Read 49619 times)
project: FlatShopRat
« Reply #90 on: May 16, 2017, 03:59:36 PM »
gotta go historical if you can.
state farm current list:
2003 silverado with comp and collision $78/mo
2007 fusion with comp $68/mo
1986 Jetta with comp historical  $12/mo
had:
1988  XJ with comp historical $7/mo
multi vehicle discount is 15% off
i'll text you two contacts to get quotes from.
« Last Edit: May 16, 2017, 04:44:30 PM by KingtheZJ »
Re: project: FlatShopRat
« Reply #91 on: May 16, 2017, 05:28:43 PM »
your truck number sounds way high compared to what i pay for my RAM with real numbers and collision / 500deduct
shit jeeps are like 130-150 every 6 months state min
they want 175 / 6 month for a 1952 other state min.
cant find a way to see a break down per car on giecos site
« Reply #92 on: May 16, 2017, 10:00:59 PM »
steering in, brake assembly mount started.  looks like the fire wall need some steel to stiffen it up to take a petal assembly.  everything was under the floor in the 52 running gear.
« Reply #93 on: May 16, 2017, 10:26:42 PM »
Monthly $. Basic coverage is very good since I have a personal liability umbrella as well that requires high minimums. I think 250/500/250. Ram comp and collision deductible is either 250 or 500.
Liability $1m umbrella $13
07 ram full coverage $61
98 tdi $42
04 1.8t $38
Gus withdrawn from use $14
Trailer 10k agreed value $8
Lino Reale State Farm in victor. Paul's buddy Steve used to work there, Erik uses him too. Good guy. He knows what I've got and what I do.
carchameleon
« Reply #94 on: May 17, 2017, 05:37:51 PM »
i had multi car discount with geico
i now have state farm (Van Travis in brighton)
sasha and i are on same plan
i still get multi car discount (i'm the only driver on the cj)
don't remember how much but was comparable with geico, i think it was a little better actually
we also have home owners and umbrella coverage and life ins. (plus 3 vehicles)
« Reply #95 on: May 18, 2017, 02:06:20 PM »
« Reply #96 on: May 23, 2017, 12:05:01 AM »
3 wheeler?  thats odd and lame.
« Reply #97 on: May 23, 2017, 12:07:14 AM »
back to work on this guy tonight.
firewall plate made and welded in
hydroboost assembly and petal assembly bolted in
steering res mounted, Hydro lines extended
radiator mocked up
falling together no issues still.
« Reply #98 on: May 23, 2017, 04:23:10 PM »
ECM on its way back
exhaust ordered
« Reply #99 on: May 23, 2017, 11:25:31 PM »
Radiator / fan / trans cooler assembled and mounted.
lower hose run.  need to order a bushing and another common hose for upper.
intake / filter / maf decided.  need to grab a 3" elbow from lowes tomorrow.
DBW bits pulled from harness
AC compressor removed
should be running this weekend if i can get my shit together and not be distracted by customer work.
« Reply #100 on: May 25, 2017, 11:54:48 PM »
drove out of shop tonight, no more pushing!
need to tidy up some things but good progress!
« Reply #101 on: May 26, 2017, 10:01:09 AM »
ECM came yesterday so i cranked a little on this guy.
hack fired motor with loose wires, started on first try
needed a quick LT1 swap site check to get the DBW to work.  lost power somewhere to TCM module. easy fix.
after initial success and motor fire, mounted ECM, TCM
Cleaned up and wrapped engine harness mods
mounted battery
ran wires for ignition relay
ran wires for fan / fuel pump relay
fixed broken temp senor wires
ran heavy gage starter wire
starts with a key and moves with pulling shifter cable.
brakes and steering seem like there is no pressure but i was getting a lot of foam (had to add 2' of hydro boost hard line, opened that system.
brake pedal may need to be extended.  steering wheel is BIG
will wait to adjust that to when i get a seat.
exhaust came.
hopfully the upper radiator hose will come today
need to change oil and hook up trans cooler
fluids
finish wiring
add lights wiring
figure out wipers
mount seat
mount throttle petal
« Reply #102 on: May 26, 2017, 02:30:10 PM »
Baller!!
« Reply #103 on: May 27, 2017, 12:02:34 AM »
cooling system 100% complete
cats and muffler deleted, fresh 3" exhaust and dynomax race bullet installed.
parked for jeep work rest of today.
« Reply #104 on: May 27, 2017, 12:24:31 AM »
pretty fun
