Author Topic: project: 1949 FlatShopRat  (Read 49624 times)
Re: project: FlatShopRat
« Reply #120 on: May 31, 2017, 06:12:11 PM »
just went over paper work..
i was wrong.  VIN decode says this thing is 1.5ton 1949, not a 1952
« Reply #121 on: June 01, 2017, 11:28:42 AM »
statefarm wants pictures
I will need you to please take the following photos of both historical vehicles and email them to me:
Front
Rear
Driver side
Passenger side
Engine
Dash & seats.
to the question:  repairs and restoration was made using only jeep and chevy parts correct?  yes     ::)
see how that one goes
« Reply #122 on: June 01, 2017, 01:31:00 PM »
That's an interesting question to ask.
« Reply #123 on: June 01, 2017, 02:49:09 PM »
Liar, your bench seat was from a Toyota or something
« Reply #124 on: June 05, 2017, 10:22:35 AM »
trans pan filter and gasket changed, new fluid
trans cooler plumbed in
driver door mech freed up
« Reply #125 on: June 05, 2017, 01:22:07 PM »
1.5hrs @ DMV strike one
got further than i expected.
rando behind counter says i need another form filled out by past seller since i have not possessed it for over 1 year.   Also claims i need weigh slip, as there are no other 49 chevy pickups registered in NYS right now and it doesnt come up in the vin system
« Reply #127 on: June 05, 2017, 02:58:04 PM »
good info, but not helpful.
« Reply #128 on: June 05, 2017, 04:56:59 PM »
They might accept that for weight?
« Reply #129 on: June 05, 2017, 10:56:57 PM »
DMV people are idiots
i should have to re weigh because im not changing registration class.  it is a CC truck, but unknown to them status.  i showed him the picture with the plack on the door where i got 6820 from i wrote on all paper work.  supervisor said no good, need weigh slip.  i was stuck anyway with out the 6th form filled out missing MV51B by sellar since i have not had possession more than 1 year.  didnt find that "rule" on the internet.
has high and low beam head lights, and one tail light hooked up right now.  if i was not 3 beverages in i would have run it down to the CAT scales, but still need paper from sellar so no rush for another lunch trip.
headlights were also sealed beam 6 volts.  swapped for what was in my CJ7 before i replaced them with new.  all good.
Re: project: 1949 FlatShopRat
« Reply #130 on: June 08, 2017, 09:31:53 AM »
drove out to Pavalion and met sellar for last paper work filled out hopefully.  Cool guy with cool projects in his shop.  5 min from JJs place.
tucked behind apartment till next week.  Needs to get scaled then a DMV trip for plates.
needs signal lights finished, horn installed, wipers and probably a new battery to be inspect able.  fun to drive!
« Reply #131 on: June 08, 2017, 09:38:45 AM »
'49 doesn't require signal lights...  8)
« Reply #132 on: June 08, 2017, 09:43:56 AM »
« Reply #133 on: June 08, 2017, 10:20:30 AM »
Would this help?
« Reply #134 on: June 08, 2017, 11:52:22 AM »
hmm, i dont think i have a 4 way flasher button on the unit though.
got this:
https://www.summitracing.com/parts/upd-a5007/applications
guess i need this then?
https://www.summitracing.com/parts/upd-5007r/overview/
