Author Topic: project: 1949 FlatShopRat  (Read 49616 times)
Re: project: FlatShopRat
« Reply #105 on: May 27, 2017, 10:56:13 PM »
seat mounted
slides and bottom folds up for storage underneath.  comfy and good room
coolant res mounted
needs plates next week :)
« Reply #106 on: May 28, 2017, 10:49:56 PM »
gas pedal mounted
brake pedal extended and moved.
first shop lot burn out check.
lot test says the cab is noisy and bouncy.  need to get some door latches on order.
needs plates and inspectable items run
wipers will probably be the biggest hassel.
« Last Edit: May 28, 2017, 11:03:54 PM by M4wdFab »
« Reply #107 on: May 28, 2017, 10:58:54 PM »
12v conversion wiper motor is ~$150 :o
« Reply #108 on: May 28, 2017, 11:05:08 PM »
gas tank pulled and looks mint.  cant remember if you needed parts from that mark.  filler neck good too.
seat frame pulled.
tomorrow i plan to hook the trans shift cable to the PTO knobs on the dash  8)
« Reply #109 on: May 29, 2017, 12:35:46 AM »
I think I have a ram wiper motor. Definitely have a vw wiper motor. I'm sure you have yj stuff but lmk if you want to check those out.
« Reply #110 on: May 29, 2017, 05:04:04 PM »
« Reply #111 on: May 30, 2017, 09:13:33 AM »
meh, ill probably end up building one.  i need closer to 14'
looking for a vintage look also, not Swiss cheese side look
« Reply #112 on: May 30, 2017, 09:36:17 AM »
trans shifter done.  its fun.
front hood chevy emblem re mounted
front bumper trim piece mounted
eyed up the front bumper, have a plan
« Reply #113 on: May 30, 2017, 11:00:20 AM »
most importantly the mouse house smell is gone with the old bench back set removed!  yesssss
« Reply #114 on: May 30, 2017, 01:49:17 PM »
put in for historical quotes to Spencer's contact for the CJ and 52.
« Reply #115 on: May 30, 2017, 02:49:17 PM »
is this the replacement of shop shovel?
« Reply #116 on: May 30, 2017, 03:09:34 PM »
no, just a project.  its 2wd and a flatbed.
not useful for snowplowing or picking up cars
« Reply #117 on: May 30, 2017, 05:31:12 PM »
not bad spencer
130$ for 6 months @100/300/50  total for CJ&52. they also asked to quote ram and ZJ
« Reply #118 on: May 30, 2017, 08:47:18 PM »
i love that a hall a million mile engine can still do a burnout !
« Reply #119 on: May 30, 2017, 11:26:46 PM »
Front bumper mounted
oil change
oil cooler block off plate installed.
tested lights with a battery charger.... they all amazingly work... except one of the signals i may have burned out with 12 volts..... for too long
head lights high and low, fog lights and front signals all light up.  crazy.
