Author Topic: project: 1949 FlatShopRat  (Read 49570 times)
Re: project: FlatShopRat
« Reply #75 on: May 12, 2017, 08:59:25 PM »
Just the transfer station
« Reply #76 on: May 12, 2017, 11:06:51 PM »
got to stare at this guy in daylight.  i love it.
started on front passenger center cab mount reconstruction.  going to weld 16gage steel in like a farmer.
need a bigger shop.
« Reply #77 on: May 13, 2017, 06:02:49 PM »
its awesome
« Reply #78 on: May 13, 2017, 09:59:16 PM »
Looking good.
Wheel and tires look fine.   Run em
Your making me want to start another build
« Reply #79 on: May 13, 2017, 10:26:37 PM »
both sides floors rebuilt and tied in to fire wall and a pillars,  Cab is a unit once again.  sitting on rubber bolted down in 6 places with doors that open.
Side steps re hung
that was an M4 14hr day today....
out of mig gas.
hit list
send ECM out
oil cooler provisions
order radiator
gages
ignition and lights wiring
front bumper hang
extend hydroboost lines
mount brake assembly
mount DBW gas petdal assembly
mate steering shaft
air cleaner
decide on exhaust or leave.
bench seat
flat bed
« Reply #80 on: May 14, 2017, 12:26:14 AM »
the next one, i think ill def look for a better cab,  this thing was pretty shot.
cant believe how it fits on the frame like a glove though
« Reply #81 on: May 14, 2017, 08:23:14 AM »
gonna slam it or leave it at ride height?
« Reply #82 on: May 14, 2017, 08:43:36 AM »
pics above are at where its gona be.
not going for a low rider, just a farm truck
« Reply #83 on: May 14, 2017, 10:13:25 AM »
Holy shit you work fast. Floors must not have been too bad to patch up?
« Reply #84 on: May 14, 2017, 10:08:58 PM »
14hrs lab in my shop = it was a pain in the fucking dick but a good start to being done right when i get more mig gas.
not much done today by the time i got to the shop.  Front bumper cut apart and prepped for install.  ECM pulled and packed up to send out tomorrow.
« Reply #85 on: May 15, 2017, 11:25:24 PM »
summit order and ebay orders placed, 95% of all components needed for completion ill have next week
dropped ECM to post office to send to LT1
HTR core in and out holes tapped and plugged on the 6.0
52 column pulled, pull all van and all 52 steering parts on the bench.  went together great, using most of the van parts adapted to a shortened 52 column.  it fell together with no issues and will be awesome.  as long as my measurements were right.
had to cut 52 fire wall to get column out as its an assembled unit to the box.  70 year old grease is awesome.
should steer tomorrow.
needs a driver tie rod end.
« Reply #86 on: May 15, 2017, 11:27:00 PM »
delphi car show June 20.
thats the drive out goal.
havent had this much fun in a while on a project.
« Reply #87 on: May 16, 2017, 09:51:51 AM »
van steering is really neat.
i ended up using all the parts to make it easy and get around the LS headers.
The shaft tube will bolt to a bracket welded to the frame coil spring mount.
buried in 70 year old grease, there is a 3/4" shaft in the 52 column that adapted right up to van parts / column bearings.  turned out awesome.
need to install tonight and make the coil bucket bracket.
orange anchor
« Reply #88 on: May 16, 2017, 01:37:50 PM »
I agree, I used all the bus steering components.
« Reply #89 on: May 16, 2017, 03:36:01 PM »
gieco quoted a 52 chevy at 175$ every6 months.
i guess if im going to have 4 sets of plates i should run some quotes else where.  gieco seems to not give mulit discounts with single drivers.
