Author Topic: Troyphy truck  (Read 85257 times)
Re: Troyphy truck
« Reply #105 on: July 23, 2017, 08:38:09 AM »
looks tall in front
Re: Troyphy truck
« Reply #106 on: July 23, 2017, 09:24:54 AM »
its got a good amount of brolean since rear leafs are pretty much flat, new springs should level it out, 6ft to top of the roof
Re: Troyphy truck
« Reply #107 on: September 24, 2017, 08:26:10 AM »
smike widdled me up this sweet spacer so i now have a 205 mated to a c6. floorboards started and seats mounted
Re: Troyphy truck
« Reply #108 on: October 15, 2017, 09:14:54 PM »
Been making small amounts of progress and down to some final items, if anyone has any of this stuff laying around available for purchase lmk
1 3/4 toob
Remote reservoir shocks
48" light bar as well as cube lights
4 or 5 point harnesses
Red or yellow led oval lights
Muffler
Any 2.5 wide leafs I can add to my stack
1 35"x12.5/17tire
1 h2 rim for said tire
Re: Troyphy truck
« Reply #109 on: October 15, 2017, 10:11:31 PM »
Muffler
I have XJ lift springs. Free (broke)
Need more info on what muffler you need. I have stock XJ mufflers, If I remember correctly they're 2.25"
« Last Edit: October 15, 2017, 10:15:06 PM by TrailTamer »
Re: Troyphy truck
« Reply #110 on: October 15, 2017, 10:35:00 PM »
I think I’m sitting on my good 3” magnaflow muffler from the Dakota. I’m “sure” I’ll use it eventually? Oval case stainless. Not small. Centered one end offset on the other.
Have one 5pt harness from 571. I think the modified one. Way expired.
I will have some 6” oval leds after I do trailer lights. Only one good amber, 2 or 4 good red. May have a couple more spare reds as well. Plug in bullet connector types. I think I have a few pig tails too. Everything from the trailer wiring will be scrap too.
Have some H2s. All have heavy rock rash or curb damage. Best may be ok. Rest should probably just scrap...
Re: Troyphy truck
« Reply #111 on: October 16, 2017, 05:41:16 PM »
brett ill definately scoop those leafs tomorrow eve if your around
i need 4 red 1 yellow so that will be perfect mike, maybe even grab 2 of the h2's
question, can you use a tranny cooler as a oil cooler?is there really any difference?
Re: Troyphy truck
« Reply #112 on: October 16, 2017, 05:53:10 PM »
I've never dug into that. there may be flow or pressure differences but I've used them interchangeably with success...
Re: Troyphy truck
« Reply #114 on: January 26, 2018, 07:23:06 PM »
Updates Troy?
Re: Troyphy truck
« Reply #115 on: February 09, 2018, 09:02:06 PM »
Updates Troy?
nothing to report ,just a bunch of shelved parts, maybe once koh hype dies down i can talk m4 into hosting a build party some weekend
Re: Troyphy truck
« Reply #116 on: March 14, 2019, 08:48:25 PM »
updates troy been over another year :)
Re: Troyphy truck
« Reply #117 on: March 15, 2019, 08:47:06 AM »
I see hes got a nice new kitchen!
Re: Troyphy truck
« Reply #118 on: March 16, 2019, 04:22:44 PM »
stop it!its only been 2 years
Re: Troyphy truck
« Reply #119 on: May 12, 2019, 05:25:04 PM »
1 Ton tie rod mock-up .How do the angles look? I there anything i should change?
